Please Help this Mechanic
Old Apr 22, 2006 | 01:19 PM
rick lambert's Avatar
rick lambert
sorry
Old Apr 22, 2006 | 02:06 PM
pablocruise's Avatar
pablocruise
Perhaps a fellow forum member could drop by and give a listen.
Location?
35K is waaaaaaaaaaaaaay too early for a valve job and timing chain.
Unnecessary parts, repairs, and charges. Did the "old" parts get saved?
Pull the vette outta that shop(and harm's way).
Old Apr 22, 2006 | 03:52 PM
VenkmanP's Avatar
VenkmanP
Originally Posted by Corvette Kid NC
I'd forget helping this mechanic and cut your losses. They sure have thrown a ton of parts and labor at a car with low mileage and a minor driveability problem. Me-thinks this guy is an incompetent boob, a scoundrel or both.
You're getting raped. Find an actual mechanic.
Old Apr 22, 2006 | 03:56 PM
VenkmanP's Avatar
VenkmanP
Also, don't start multiple threads on the same topic:
http://forums.corvetteforum.com/show...post1554856327
Old Apr 22, 2006 | 06:58 PM
MR NICE's Avatar
MR NICE
No way should your car need a valve job,unless it was not mantained.Check the vibration dampner it may be loose??
Old Apr 22, 2006 | 07:49 PM
CFI-EFI's Avatar
CFI-EFI
??? Are you pimping for Corbird's mechanic?
Just rotate the radio ***** and change the air in the tires and you'll be all set.
RACE ON!!!
Old Apr 22, 2006 | 09:28 PM
aminnich's Avatar
aminnich
Originally Posted by redrose
in over 40 years of playing with sbc's, i have seen 2 that started to make a substantial ''knock'' after running for more than 30 minutes...both were 100k+ miles with (discovered when heads were pulled) extreme carbon build-up on piston top....removal of carbon cured both (do this only with solvent--do NOT scrape)...theory is that connecting rods expanded with heat soak and deck clearance went negative....your low mileage does not fit this scenario, but if the new head gaskets were thinner than old ones, its a distant possibile cause (but we're really distant here, reaching way down)
like others, i am very uncomfortable with the repairs which were deemed ''necessary'' for such a low mileage vehicle,tho
Aside from the mechanic, who may or may not be competent the above suggestion is the only one I have seen that presents a plausible cause. I am neither defending, nor accusing the mechanic, but trying to redirect this back to a problem/solution needed thread, with no offense to anyone. With a new valve job, meaning new head gasket Redrose's comments certainly seem plausible, almost likely.
Any others?
Old Apr 22, 2006 | 10:41 PM
highpockets's Avatar
highpockets
Have YOU personally seen/listened/driven the car since these"repairs" were completed ? Has anyone run compression test/pulled valve cover(s) and inspect valvetrain since then ? Had one that baffled us,slight miss when warm,slight tapping noise,compression down about 15 psi(use a high quality,accurate gauge and test all cylinders identically) Upon removing Dr side head,we found #1 piston NOT coming up to TDC,about 1/4 inch below deck ! Pulled engine,#1 rod BENT,piston skirt/pin boss rubbing(knocking) on crank counterweight ! Guessing it got some coolant in one cyl from previous(and poorly done) intake gasket replacement,cylinder hydraulic slightly and off she went ! I second/third other suggestions to politely remove your car from current facility and perhaps explore a different "mechanic" maybe a local forum member could suggest/direct you ! PM me if you would like me to email you a pic,I kept the BENT rod/damaged piston as a souvenier
