Trans question 86 shift points
Old Apr 22, 2006 | 09:10 PM
plumberh2o's Avatar
plumberh2o
Default Trans question 86 shift points
I need to change my shift points from 5000 to 5500 is this possible and just how easy is it to do?
How much will it cost to do it?
Guys need a little help>
Old Apr 22, 2006 | 09:17 PM
Pete K's Avatar
Pete K
The governor, located on the side of the trans, is easily altered to adjust the shift points. The hard part is knowing the correct springs and weights (in grams) of the unit. In other words, the labor is easy, but the correct combination of parts will be trial and error. Most guys who know, will not part with the info. B&M and others make adjustable shift point kits that contain a good assortment of springs and weights to get you started.
Old Apr 22, 2006 | 09:45 PM
plumberh2o's Avatar
plumberh2o
Ok we are going to start taking apart this 700R4 trans. Can't we just buy a part that does this and replace it.
Old Apr 22, 2006 | 10:19 PM
Fubar569's Avatar
Fubar569
no, the governor on the trans is the only way with these units. the springs & weights determine the shift points. i hope mine are adjusted properly by mad dog. if not, then i guess i'll be shifting manually at the strip
Old Apr 22, 2006 | 11:10 PM
Rich & Lisa_84's Avatar
Rich & Lisa_84
From: I live at www.domesticlugnuts.com I sleep in PA
I have a Mad Dog TRansmission in my Vette. If I lock it into 1st, it still shifts at 5000 rpm. I will be calling him soon to get the correct springs and weights to move that up to 5800 - 6000 rpm.
So far it seems to be a good transmission.
Old Apr 23, 2006 | 08:54 AM
Pete K's Avatar
Pete K
There is a guy on ebay who claims he can sell you a governor with the shift points you desire. He mods them to suit your taste. I believe he gets$90 for this. Run a search on 700r4 and have a look.
Old Apr 23, 2006 | 11:08 AM
corvettemaster's Avatar
corvettemaster
and unless you are rebuilding the trans, installing a shift kit, etc. there is no need to take it apart to just change the shift points. you don't even have to drop the tranny pan. the governor is located towards the rear tail housing and can be accessed with the trans in the car
To Trans question 86 shift points
