burping the radiator
Old Apr 24, 2006 | 02:28 PM
mudslide's Avatar
mudslide
Default burping the radiator
Ive been reading that the radiator needs to be burped but on my1990 the radiator cap and little fill station is much higher than the engine,only the plastic overflow tank is lower. I drained some out to clean my TB and it was pretty dirty so I will flush it out and refill. Do I have to jack up the car and go trough the burping prosess with the fill higher than the engine or is that just for the older C-4s?
Old Apr 24, 2006 | 02:38 PM
CFI-EFI's Avatar
CFI-EFI
A little slow, are we?
Originally Posted by Advanced Search: "Burp + Radiator"
Showing results 1 to 15 of 15
Search took 3.62 seconds. Search: Key Word(s): burp, radiator ; Forum: C4 Tech/Performance
It is not unlike air foils.
RACE ON!!!
Old Apr 24, 2006 | 02:47 PM
aminnich's Avatar
aminnich
LT1s have a bleeder screw pass side by throttle body, not sure about yours. Take a look for one.
mudslide's Avatar
mudslide
YES to much still dont see the part where about if my fill being above the motor is ok to just fill. Guess ill burp it anyway its not that much to do
Old Apr 24, 2006 | 03:35 PM
NEVRL8T's Avatar
NEVRL8T
Originally Posted by CFI-EFI
A little slow, are we? It is not unlike air foils.
RACE ON!!!
Nice answer! That will really help!
Old Apr 24, 2006 | 03:49 PM
redrose's Avatar
redrose
burping an l98 is a waste of effort--won't hurt, just the hard way of doin things...i just top up the rad each day for about a week and everythin's ''groovey''...even if you do do burp it , you'd be a dummy if you didn't check it at least a couple times to be sure there are no leaks
Old Apr 24, 2006 | 06:27 PM
mudslide's Avatar
mudslide
Thanks I will do just that
Old Apr 24, 2006 | 10:03 PM
Darkgh0st's Avatar
Darkgh0st
To burping the radiator
