1985 C4
Old Apr 24, 2006 | 10:05 PM
tuk1985's Avatar
tuk1985
1st Gear
Default 1985 C4
Hi,
Does anyone know where the wire for the low coolant wire orginates from? I see the connection at the side of the radiator but cant find the wire that should be connected to it. Second.. What is the correct altenator that this car came with 120 or 140 amp. 3rd Power steering fluid is gray, leave it alone or replace it. Ill send pics of the ride soon. 4th I have two fans one behind the radiator and one infront underneath the car near the scoop Is that for the ac unit? Thanks
Tuk
Old Apr 24, 2006 | 10:38 PM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
Somebody must have put another later C4 radiator in your car, 85 does not have a low coolant light, at least mine doesn't. If I'm wrong someone please set me straight.
Alt is a 140 amp and all by itself for 85. Check tech tips for a how to on upgrading to a newer and better alt.
I'd change the power steering fluid, I used Valvoline's synthetic and it works great.
The fan between the radiator and the engine is the main fan and the outer one is the auxilliary.
Old Apr 24, 2006 | 11:52 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
85 does not have a low coolant sensor, you have a replacement radiator in there.
I think the alternator changed in 86, not sure what the 85 is rated at. I believe the one on my car is the original alternator though, 21 years, not bad at all!
Old Apr 25, 2006 | 01:21 AM
BVVHO's Avatar
BVVHO
The 85 Alt. is a 120 amp. Still have my original. No low coolant light.
Old Apr 25, 2006 | 12:19 PM
Fasterer's Avatar
Fasterer
My 85 only has the one fan between the radiator and engine. I also would change the power steering fluid. Acording to my FSM your 85 should have Delco Remy #17SI 7216 alternator rated 108 amps (rated hot output)
Bill
Old Apr 25, 2006 | 01:22 PM
mikey whipreck's Avatar
mikey whipreck
Stock alt for '85 is 108 amp.
Unless yours was built with the "high output" RPO, which was 120 amp (check Bogus' RPO faq if your not sure).
It's never a bad Idea to change fluids if your unsure as to its' condition and age.
Old Apr 25, 2006 | 03:22 PM
champs65's Avatar
champs65
Thanks guys, I have always been curious about that single spade lead (with no plug for it anywhere) on the right of the radiator on my '85.
Now I know!
To 1985 C4
