Not Another Distributor Gear!!!
Old Apr 24, 2006 | 10:29 PM
severe-1's Avatar
severe-1
Default Not Another Distributor Gear!!!
During a cap and rotor swap 2yrs ago, I noticed alot of slop in
the distributor rotor. I removed the rotor and the gear was half eaten!!
After calling Cam Motion where I had ordered the cam. he said it was strange and told me to replace the gear with another stock gear.
The cam was ground on a stock blank and should not require a special gear.
Fast forward till today...
Went to change cap and rotor and the gear was eaten again!!
I carefully inspected the cam gear and it looks perfect...
What could cause this? The gear is half worn away. The distributor spins freely and I have up and down freeplay when the distributor is installed...
WTF- Its been around 20,000mi since last changed
Old Apr 24, 2006 | 10:33 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Ouch good thing you caught it before it dumped in the pan. (nice avatar pic btw )
Is this a rollercam motor?
Pete K's Avatar
Pete K
A bent shaft will cause this. No one thinks to check the runout on the shaft. I did not figure it out till it ate 3 gears and eventually the cam.
Old Apr 24, 2006 | 10:57 PM
severe-1's Avatar
severe-1
Yes, It is a rollercam motor, not from the factory though...
How do you check distributor shaft runout?
Old Apr 24, 2006 | 11:01 PM
Pete K's Avatar
Pete K
I took a couple pieces of wood and made a v notch in each so the shaft (after it was removed from housing) could lay in it. Then I set a dial indicater in it and spun it.
Old Apr 24, 2006 | 11:07 PM
severe-1's Avatar
severe-1
Thanks Pete,
I will try that tomorrow. My car is an 86. It seems to be an oddball when it comes to distributor parts (HEI with screw down cap).
What did you replace your distributor with?
Old Apr 24, 2006 | 11:11 PM
CentralCoaster
I think the screw down cap was to distinguish the TPI units from the other HEIs. The TPI one is shorter. I don't know if the difference is the distributor itself, or cap, or both.
Old Apr 24, 2006 | 11:14 PM
Pete K's Avatar
Pete K
Originally Posted by severe-1
Thanks Pete,
In my case, a nitrous backfire bent it. I had a spare junkyard stock unit laying around. I robbed the shaft out of it, checked it and have been using it ever since.
Old Apr 24, 2006 | 11:47 PM
severe-1's Avatar
severe-1
I wonder if an older shaft will fit into the newer housing?
I have several HEI units laying around. I'll have to investigate that...
Does MSD have a replacement distributor for an early FI car?
Old Apr 25, 2006 | 01:58 AM
pablocruise's Avatar
pablocruise
Do you have a hi-vol oil pump?
Old Apr 25, 2006 | 06:43 AM
adi4's Avatar
adi4
I had a problem like this with a Range Rover V8 that had a high volume oil pump fitted and it was eating dist gears, we lowered the oil pressure a little and that solved the problem.
Old Apr 25, 2006 | 07:06 AM
comp's Avatar
comp
interesting
Old Apr 25, 2006 | 07:20 AM
Red Tornado's Avatar
Red Tornado
last year, i called melling and asked about distributor gear wear with their high volume oil pumps.........tech guy said in 25 years he has never heard of premature wear with GM, although he's heard of a few on Fords.........exactly why this is escapes me at the moment, of course this is anecdotal anyway.
Old Apr 25, 2006 | 07:40 AM
Pete K's Avatar
Pete K
A high volume pump has bigger, heavier, gears. The need more grunt to turn them. Distributor gear wear on small block chevys has always been an occasional issue. I suspect he was either the new guy, or lying.
Old Apr 25, 2006 | 04:31 PM
Davemc1963-87conv's Avatar
Davemc1963-87conv
Make sure you are using the GM Melonised gear (10456413) and not ste 'old' iron GM (1958599) gear. This is used on all roller cam engines and is the recommended gear for Tpis cams which also don't need a 'special' gear. It can also be used with flat tappet cams.
Dave
Old Apr 25, 2006 | 09:23 PM
AKS Racing's Avatar
AKS Racing
Severe-1,
I will say that your gears paled in comparison to my combo that used to eat distributor gears. Mine would eat through the total gear in less than 3K miles (once stranded, and the 2nd time caught in time). I eventually checked the distributor depth and determined that it was riding too high on the cam gear. This all began when I added the TPIS Mini Ram II. I eventually went to the MSD adjustable collar distributor and have not had any issue in the last 5K+ miles. I pulled the distributor this last weekend (switched to a C4SP intake), and the distributor gear and the can gear looked perfect. I again readjusted the collar an additional 0.015 to set the proper distributor gear installed height in the Weiand Team G intake.
I hope this helps,
Aaron
Old Apr 25, 2006 | 09:47 PM
Red Tornado
he had to have lied then. he was in his early 50's and had worked as a tech at melling for about 15 years, if memory serves. nonetheless, he was definitely not new there.
its strange he lied, i wasn't buying anything from them, it was an info hunt.
To Not Another Distributor Gear!!!
Old Apr 25, 2006 | 09:52 PM
Pete K's Avatar
Pete K
The distributor gear problem was never a huge, common problem. Not extremely rare either. Why he did not know about it is unusual. Kick him in the box
Old Apr 26, 2006 | 12:52 PM
Gamewood's Avatar
Gamewood
My custom comp cam ate through the original roller cam gear. I've since switch to the comp cam composite gear with no further issues. For the record, summit only lists the 0.500" gear but you need the 0.491" gear...learned the hard way of course.
W
Old Apr 26, 2006 | 01:23 PM
danno85's Avatar
danno85
Dave
Exactly. I had wear on a roller cam (not a steel billet, but the carburized metal, whatever that is) with a stock iron gear, even though the cam manufacturer said a stock iron gear would work. I switched to the GM melonized gear and have had zero problems.
Dan
