L98 speed density runs bad when hot...
iron heads, forged pistons, around 9.5 comp ratio and DPFI, TPI style with ZZ9 cam.....
so the question is as I recall, I adjusted the valves with cold engine, and so everything has been fine for some time now, EXCEPT when in hot weather the engine warms up totally, NOW on these 80f+ days it's running fine TEMP wise, but runs like crap....I have been all through this damn dawg, and am thinking computer screw ups...but....the thought hit me, when engine is cold and/or in cold weather for Florida that is....40-60f outdoors, car runs fine.....70f++ it has more misses than a HS Prom....so....
I have been adjusting hydraulic valves for decades untill snug...is there a possiblility the engine heating up causes a valve to stay open causing a misfire?? can this happen?? I adjust untill snug on the pushrods, and no further....
any clues ??anyone/??
I have been all through sensors, no codes set, the 1227730 computer has been replaced many times, wiring checked, thing been petted over so many times it's a joke, the cyberdyme a/fuel gauge hooked to the O2 sensor says it goes lean as hell, and so does my voltmeter, runs fine cold, but when goes closed loop at about 160f or so, the O2 starts leaning it out to .1 volt or maybe less on tip in, the idle is messed up badly, and so I have lots of misses running down the road, it's embarassing it runs so badly....
I realize I"m grasping at straws on that valve adjustment, but I"m getting desperate, so do the valve adjustments tend to tighten lash when hot??
GENE
1/2 turn past zero lash is the most popular adjustment, but it is not correct for all applications. Comp cams R lifters are a hydraulic lifter that calls for a zero lash adjustment, for example. We don't have enough information about his valve train to say for certain that he should be tightening the rockers to 1/2 turn past zero lash.
Like I said though, not tightening the rockers enough will not cause a valve to hang open, which is what the original poster was questioning.
I have a sneaking suspicion I need relocate that ignition module from dist base where NO ELECTRONICS like that heat spot, designed or not, and put it on a heat sink (dist base would ADD heat to it), and stick it inside the car.....I"M an old geek, so wiring is not an issue....
the sending coil is fresh, and I have been all over this, so is the spark coil in the cap, I just reinspected it today, looks brand new still....
I have subbed MAP, and all temp sensors from time to time, even tried hanging a water temp sensor outside in the air under the hood, behind fan....THAT was an obvious no go....
OH, I bought a new O2 sensor yesterday, no go....no change what so ever....
I don't think I can log data on this scanner tool I have, I know I don't have a printer or a portable PC, much less software....
GENE
GENE
89-91 is when GM went away from the Bosch Injectors and went with the garbage Rochester injectors. This is a very typical failure on 89-91 TPI cars.
Any one have any experiences with Breathless Performance chips?? Ernie there used to be a sponsor, but I don't see them/him listed anymore, talked to him couple years ago about this and he wanted another 200 bux to look at it again....been about 6? years since I bought it....it was before I met my wife yet, and we married 5 years now...shows how much/long/many times I have fought this issue but there are only so many hours in a day and in cooler weather it's not an issue...
GENE
history has been for over 6 years now, every time i think it got it whipped, damn if that stumble don't come back again....
GENE
about the ignition module, that's why when they test them they run them through at least 10 cycles-getting them hot enough to see if their failing.Good luck.
