Fuel Pump dying??
Old Apr 27, 2006 | 10:23 PM
C4CBF's Avatar
C4CBF
Default Fuel Pump dying??
I think I am typing this thread to confirm my suspicions. I think the fuel pump is on its way out. The current engine has 155K on the clock.
Engine runs fine until you punch it and it totally feels like it is stalling or choking out. I first thought it might be dist. b/c it would only do it at 4-5KRPM but now it does it right when you hit the gas hard. It seems to be slowly getting worse. Now it revs to 2K then cuts out and comes back to life after a second or two.
Could it possibly be a regulator issue? I am going to change the fuel filter just to cover the base. What pressure reading should it read on the rails?
I am planning a total engine rebuild and if I have to buy a new fuel pump now I want to get one that can handle 600-650 bhp. Any suggestions?
Old Apr 28, 2006 | 09:26 AM
rick lambert's Avatar
rick lambert
Are you sure you don't have a cat problem??
Old Apr 28, 2006 | 09:47 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Check the sock on fuel pump. I just replaced mine and the sock was dark brown. Sunlight couldn't get through it.
Old Apr 28, 2006 | 12:12 PM
C4CBF's Avatar
C4CBF
Yeah I am going to pull that out and check it but I thought I heard that the sock isn't sold seperately . Is there a way to clean it?
Old Apr 28, 2006 | 12:19 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Possibly, if it's not all to hell.
Old Apr 28, 2006 | 01:59 PM
C4CBF's Avatar
C4CBF
What's the course of action if it isn't savable? My logic is that I am going to eventually need a better fuel pump for the motor I want to build so if it isn't salvagable just replace...
Old Apr 28, 2006 | 02:12 PM
rick lambert
You can get the sock separately, as a matter of fact you have to order the sock because the fuel pump doesn't just come with one-at least at NAPPA.
Old Apr 28, 2006 | 03:57 PM
C4CBF's Avatar
C4CBF
Would I order it from GM or an AutoZone,etc?
Old Apr 28, 2006 | 10:36 PM
jsinga's Avatar
jsinga
You can get the sock at any auto parts store.
I wouldn't doubt it if there aren't more than a handful of different ones for GM cars.
At 155k miles you are living on borrowed time on that pump.
Did you change the fuel filter?
I got a an AC Delco pump from Pep Boys when mine died. You can find a good stock replacement pump anywhere.
If you are going to upgrade I'd look into the ractronix wiring and pump upgrade and go ahead and do it.
JS
Old Apr 29, 2006 | 09:52 AM
C4CBF's Avatar
C4CBF
JS
Thanks for pointing me in that direction, I was looking at the Holley pumps on Summit. Getting the Racetronix pump install kit and wiring kit is really not a bad price. I didn't even realize to change out the wiring too. I am going to take it all apart and see what is clogged up. Thx for the help fellas
Old Apr 29, 2006 | 10:39 AM
RRT vette's Avatar
RRT vette
Rick made a good suggestion. A blocked cat could do the same as you described. I would check fuel pressure before thinking about a new pump (might be the problem and might not). Pressure should be 36- 42 psi idle. Tape the guage to your windshield and observe the pressure when the engine cuts out. If pressure drops significantly, fuel pump is probable suspect (IMO, I would change the filter if not done in a while). Bad gas, clogged FP screen, dying pulsator, or water in gas would show same symptoms. As for the cat, look under car at night when up to operating temps and observe the cat to be glowing orange or even use a rubber hammer and hit cat and listen for rattling.
Old Apr 29, 2006 | 12:05 PM
CFI-EFI's Avatar
CFI-EFI
Hook up a pressure gauge and go for a ride. If the pressure drops off there is a delivery problem. Both the filter and the sock are possibilities and each are available separately.
Not likely, especially if it holds pressure. Is there any liquid gasoline or smell in the vacuum line to the regulator? The job of the regulator gets easier as the rpms go up. The fuel pump runs at a constant speed, it is electric. As the engine speed increases, the engine uses more fuel and there is less gasoline for the regulator to deal with. Check your FSM for the fuel pressure spec for your year.
RACE ON!!!
To Fuel Pump dying??
