Changed Oil today, running rough now.
Old Aug 21, 2001 | 07:48 PM
C4 Suke's Avatar
C4 Suke
Default Changed Oil today, running rough now.
I changed the oil today, used mobil, 10w-30, purolator filter. It use to run smooth now its a little rough, especially when I'm stopped. Does anyone know what they problem might be? Thanks, Suke.
Oh yea, its a '95 LT1 automatic.
[Modified by C4 Suke, 5:49 PM 8/21/2001]
Old Aug 21, 2001 | 08:29 PM
GlockLT4's Avatar
GlockLT4
Default Re: Changed Oil today, running rough now. (C4 Suke)
My only thought would be that changing the oil might have lossened up some sludge in there. You did have Mobil 1 in there before??
Old Aug 21, 2001 | 08:32 PM
C4 Suke's Avatar
C4 Suke
Default Re: Changed Oil today, running rough now. (Glock'94)
It's always been using Mobil 1. When I drained the old oil, it was pretty black... maybe I should put some additive like Lucas?
[Modified by C4 Suke, 6:33 PM 8/21/2001]
Old Aug 21, 2001 | 08:37 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Likely little connection between the new oil and running rough unless in the process of changing the oil, you in advertently dislodged an electrical connection or some other such thing.
Recheck the areas in which you worked
Old Aug 21, 2001 | 08:41 PM
C4 Suke's Avatar
C4 Suke
Default Re: Changed Oil today, running rough now. (jackdaroofer)
Well, I also changed my rear brakes, added a new resoviour and cap, and removed old coolant and put in new coolant. Along with running rough it is overheating.
Old Aug 21, 2001 | 09:00 PM
jackdaroofer
Cruise-In I Veteran
Cruise-In V Veteran
see my reponses to those posts
Jack
To Changed Oil today, running rough now.
