Intermittant Horns?
Old Apr 28, 2006 | 04:02 PM
90EXPVette's Avatar
90EXPVette
Default Intermittant Horns?
Guys I've got a question for you.
The horn on the '90 will only work when the engine is cool. When it's at operating temp...nothing but once it cools off they work normally. Where should I start looking to troubleshoot it?
Thanks,
Old Apr 29, 2006 | 11:48 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
I have the opposite problem, my horns won't stop blowing until I pull the fuse or disconnect them.
The culprit in my case is the horn switch, on the later years('94 and up)they used a cheesey thin plastic switch that breaks easily. SInce the '90 has a slightly different steering wheel, I don't know if the switch is the same or not as my '95.
I have a new switch on order, just waiting for it to come in. Expensive little bugger, friggin'$20.
