MSD ignition system
Old Aug 21, 2001 | 10:27 PM
aholmes's Avatar
aholmes
8th Gear
Default MSD ignition system
I'm considering installing an MSD ignition system on my 95 LT1. Anyone done this before? Where did you mount it?
Old Aug 22, 2001 | 08:15 PM
No Ordinary 91's Avatar
No Ordinary 91
Cruise-In III Veteran
Default Re: MSD ignition system (aholmes)
i did one on my 91 which is an L98 i do remember reading on how it would be hooked up to a LT1 and i think that there is a harness from MSD i mounted mine under the driver side headlight
Old Aug 22, 2001 | 10:38 PM
notbob's Avatar
notbob
Default Re: MSD ignition system (91_Corvette)
How bad was the install time and was it something that a moderate do it yourselfer could do?
I've been thinking of doing a whole new ignition system over the winter.
Old Aug 23, 2001 | 12:05 AM
Chris@SD's Avatar
Chris@SD
The MSD certainly cannot hurt, but unless you are spraying nitrous or supercharged, you might not need it. The stock system seems to do very well, even for highly modified heads and cam cars running 11's!
Good Luck,
Old Aug 23, 2001 | 01:49 AM
No Ordinary 91
Default Re: MSD ignition system (notbob)
it took me a few hours to do, i didn't have the harness as i bought it off of a guy that was running it on a mustang, so i pulled the distributer and cut the wires and installed quick disconnects on everything to match up in the event that the MSD failed i could go back to the stock coil in a few minutes even on the side of the road
in this picture you can see the wires from the MSD red and white, its real straight forward, run a power wire, ground, and two wires from the stock harness and two from the MSD to the coil.
also if you look closely you can see where i tapped in for the shift light.
Old Aug 23, 2001 | 01:50 AM
No Ordinary 91
Also this is just after i finished the install and hadn't finished trimming for the quick disconnects, this is hooked up with straight splices to make sure it worked
Old Aug 23, 2001 | 11:29 AM
aholmes's Avatar
aholmes
8th Gear
Thanks for the info. I was planning on mounting under the headlight as well.
Old Aug 23, 2001 | 02:01 PM
Zora's Avatar
Zora
Cruise-In I Veteran
Cruise-In II Veteran
Got the MSD on my 95 LT1...mounted it in the nose of the car. Away from the weather and HEAT. :chevy I will try to get some pics for you.
To MSD ignition system
