Misfiring problems
Old Apr 29, 2006 | 06:56 PM
Medicman55's Avatar
Medicman55
Default Misfiring problems
Hey everyone,
I have been working on my car as usual, and everything I've tried, it just doesnt work. The car idles poorly, it shakes alot. when I accelerate around 60-70 mph the car shakes ALOT. I replaced some spark plugs and it didnt do anything. I tried unplugging the spark plugs, to see if I could find which cylinder it was, and the car just sounded the same. What is wrong with my car?
Medic
Old Apr 30, 2006 | 08:03 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
That ain't much info to work with
Year, any codes thrown
Old Apr 30, 2006 | 08:17 AM
rick lambert's Avatar
rick lambert
WOW-a little help from you would help us-help you. What year? Any codes?
DO you have the FSMs or Helms? forget the Haynes or Chiltons-there just not reliable for trouble shooting etc. You can get either FSMs or Helms off the internet. I got mine from ebay.
To your problem-I'd check for vacumn leaks first.
Then a complete tune-what's "replaced some plugs"? replace all 8 with new, replace dist. cap, rotor and ohm the plug wires-hope you know how to use a digital Ohm meter. Plug wires should ohm at 5000 per foot. You might also observe the plug wires at night-look for arcing.
Then do a fuel pressure test.
You'll also want to check ignition modul, and pick up coil.
Then we can go on to injectors?
Now you should be able to see the benefits of owning a FSM-cheap, about $100. for both books. Without them you may be trying to find the problem for quite sometime!!
AND BTW-you could have something as simple as a crossed plug wire.
Old Apr 30, 2006 | 08:23 AM
RRT vette's Avatar
RRT vette
Rick made some good suggestions. I will add to it and say, idle the car and unplug the injectors connectors one at a time not any change (idle should drop with each). While there unplugged use an OHM meter and test the injectors and see what #'s you get. Should be around 16+/- ohm each. With a little more info on what is going wrong we will be able to pinpoint more accurately. What do plugs look like?, what does the exhaust smell like?, gas mileage?, check engine light on?, does it happen hot or cold?, just to name a few.
Old May 1, 2006 | 05:03 PM
Medicman55's Avatar
Medicman55
Alright, Ill try to clear up most of your questions. I own an '86, and its been throwing code 36 most of the time. I currently took my car into a shop for a different problem, but what is code 36? Where should I start first once I get my car back?
Medic
Old May 1, 2006 | 05:32 PM
rick lambert
Code 36 is a MAF burn off circuit code, probably needs a new relay-HOWEVER, if you replace the burnoff relay-you need to replace the power relay too! both located behind battery. Although it could be a bad or coroded connections or even a bad fuel pump relay-there are step by step trouble shooting steps in the FSMs or Helms, believe me-if you can pay a mechanic once-you would have more than paid for the manuals, and future problems would be easier for you to diagnos.
Old May 1, 2006 | 05:43 PM
RRT vette's Avatar
RRT vette
This sounds correct
Old May 1, 2006 | 05:46 PM
Medicman55's Avatar
Medicman55
See, its been acting very odd lately. The Service Engine Soon light will come on, and then turn off. Come on again and shut off. Its actually quite funny watching it, but what is wrong with it? And what is a burn-off relay? How much will that run me?
Medic
Old May 1, 2006 | 06:00 PM
rick lambert
Your light is coming on-telling you a code has been thrown.
The relays are about $15. each. You would end up saving money by buying the FSMs-cause you can throw alot of money into throwing in new parts without trouble shooting first!
Old May 1, 2006 | 06:24 PM
mudslide's Avatar
mudslide
I am going to try that injector thing on my 1990 L98 ---have a skip and have replaced and cleaned almost everything Ill try that next
Old May 1, 2006 | 06:51 PM
CFI-EFI's Avatar
CFI-EFI
Medic
With all that "Check Engine" light flashing, are you sure that code 36 is the only code? The Factory Service Manual (FSM) printed by Helm inc. will tell you how to extract the codes, the source and possible causes of the code(s), and a trouble shooting chart for each of the codes. Remember, "Don't shoot the messenger". It will also explain how the various systems work, and things like what and where a "burn off relay" is and what it does. I'm afraid your trouble shooting techniques need a little more refinement and direction.
RACE ON!!!
Old May 1, 2006 | 09:43 PM
AGENT 86's Avatar
AGENT 86
Medic
Start here http://members.shaw.ca/corvette86/Code%2036.pdf
Old May 1, 2006 | 11:10 PM
RRT vette's Avatar
RRT vette
I would use the scan Agent86 posted. I't hard to understand at first but with a little studing of it you will eventually fix the code 36. This is right out of a 86 FSM.
To Misfiring problems
