94 RH power window switch....HELP!!!
Old Apr 30, 2006 | 08:44 AM
merlot566jka's Avatar
merlot566jka
Default 94 RH power window switch....HELP!!!
so i was fixing the warped door panel, noticed the rh switch pushed the window up but not down, and the orange light wasnt on. i pulled the wires out of the switch, but to my dismay they were not labeled on the switch or in the haynes manual. now i have six wires and six slots and no right combo!!! does any one know what order these go in or have a pic of the back of the switch?? any help would be great.
btw, what would cause a window to go down but not up??
thanks for your help!
Old Apr 30, 2006 | 08:50 AM
RRT vette's Avatar
RRT vette
Bad switch or open circuit. To fix this you could either get another switch or troublshoot the wires to see is the switch is actually bad or not. The Haynes manual will not tell you squat as far as this goes. A Factory Service Manual for a 94 is what you need or maybe someone here has this page in there manual they can scan for you. A picture will show where the wires connect but you need to find out if they are getting power to the switch.
Old Apr 30, 2006 | 09:48 AM
merlot566jka
gotcha, anyone have a service manual and scanner?
Old Apr 30, 2006 | 10:54 AM
merlot566jka
To 94 RH power window switch....HELP!!!
