93 Vette running gear
Old May 1, 2006 | 03:26 PM
pro1955's Avatar
pro1955
Default 93 Vette starting problem.
Friend is running 93 Vette running gear in a street rod, is using aftermarket harness with stock computer. Car won't start has fuel pressure 50 psi, checked injectors with noid tester ok, if car sits for 1/2 an hour it will start for about 5 sec. then shuts off no restart. Anyone got any ideas? I just tried starting fluid it will run on that, seems like fuel delivery problem.
Old May 1, 2006 | 03:58 PM
Scooter 94's Avatar
Scooter 94
Isn't 50 psi way too high for LT1 fuel pressure? Dunno if that could cause the problem or not.
Old May 1, 2006 | 05:11 PM
pro1955's Avatar
pro1955
I thought the same thing but you think it would start.
To 93 Vette running gear
