rebuilt 85
Anyway, I replaced the heads with the same ones, they were stock iron heads. But, the bottom end is nice for some reason its all forged with stock heads
He blew the head with less than 1K miles on the new rebuild. The exhaust is wide open up to a set of nice Borla mufflers. And, it has an aftermarket cam. I've only reprogrammed it to have the fans come on at 185 and to idle at 750 RPM. Can someone look at the cam specs and tell me if it requires further tuning? I ask because it smells rich.Intake Duration at 050 inch Lift: 204
Exhaust Duration at 050 inch Lift: 214
Duration at 050 inch Lift: 204 int./214 exh.
Advertised Intake Duration: 262
Advertised Exhaust Duration: 272
Advertised Duration: 262 int./272 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.420 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.442 in.
Valve Lift with Factory Rocker Arm Ratio: 0.420 int./0.442 exh. lift
Lobe Separation (degrees): 112
Intake Valve Lash: 0.000 in.
Exhaust Valve Lash: 0.000 in.
Any suggestions or pointers would be great as I start working this tune out.
On another note, now that I haven't got the ENORMOUS drain on ground (all that equip was hooked up through common ground, even the speakers) the digi-dash problems I was having and the rough idle has gone away. I think the electrics were just completely messed up by all that junk this guy installed poorly. I'll be running more scans once I have the harness back to stock routings.
The cam looks very similar in specs to many tame "no ecm change" combos I've seen. I just know very little about cams and thought I would ask.
