The more info I get the more I am leaning twards a C5 upgrade and moveing the front to the back. One of the links I posted has the kit on there. The steel braided lines I am going to try and do at the same time. I will research on bleading and replacing the fluid and I am sure that will make a big differance. Thanks again ScaryFast! FYI Dont tell my wife but when we refinance our home to get $ to pay off 80% of our bills I am going to sneak in and take about 1G and do the upgrade...LOL. Really though, I will have to sly talk my way for her to let me do it.
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Here's your shopping list then:
C5 BRAKE UPGRADE
PART P/N UNITS PRICE/UNIT TOTAL
Ceramic Front Brake Pads & Hardware Kit 88909667 1 49.88 49.88
13" C5 Rotor Left (cross drilled & slotted) 88926732 1 40.36 40.36
13" C5 Rotor Right (cross drilled & slotted) 88926731 1 40.36 40.36
Left Front Z06 Caliper 88895128 1 87.03 87.03
Right Front Z06 Caliper 88895129 1 87.03 87.03
C5 Caliper Abutment (RH & LH) 12455799 2 28.23 56.46
C5 Caliper Abutment Boot (2 required per caliper) 12530703 4 2.94 11.76
C5 Caliper Abutment Pins (2 required per caliper) 12530697 4 3.52 14.08
C5 Caliper Bolts (2 required per caliper...included with caliper) 14067559 4 0.86 3.44
C5 Caliper Banjo Bolt 22163795 2 2.32 4.64
Abutment to Bracket Bolts M14-2.0x35mm (Fastenal Brand) 39685 4 1.49 5.96
Bracket to Spindle Bolts 1/2"-20x1.25" * 4 1.15 4.60
plus:
2 custom 84-87 upgrade brackets (don't know source for these)
AC Delco durastop drilled/slotted rear rotors #89000483/89000484 ~$70 each
Rear pads
Earl's SS brake lines #28A080 $90 at summitracing.com
DRM performance bias spring, $12
Compare www.rockauto.com, gmpartsdirect.com, or Superior Chevy of Kansas City (w/ forum discount) for all the GM/ ac delco parts
Remove your stock rear calipers and wire brush and paint to match the front C5s. Don't move your front brakes to the back, that's a lot of work for negative gains.
I'm guessing all this will cost you about $800.
I haven't read the whole thread but in case nobody has posted this info here it is. This is the brake template for your 85 to put the C5 brakes on the front. I had 2 sets of these made at work and have them at home but any machine shop should be able to whip these out in no time. 2nd post down from Joby.
Thanks for pointing out the part about machining the holes for threads. I'll have to bring them back in to have that done. Mine were machined from steel. I work with over 30 machinists at the plant and homers are a part of life around here. They did a great job. I mentioned to them they could make some money if they started making these on the side but like anything I don't like to work on computers anymore than the work I do here or my side business in town so I can kind of see the reluctance not to do it. I haven't made up my mind on doing this upgrade just yet. Maybe in the fall/winter when I'm bored as the new engine and paint is a little more than the budget allows for this years mods.
Those are really nice but more than what I need. I think 6 pistons are great if you need them but I dont need that many. Thanks bluewasp for the link though!
If the rears lock up going into a corner, you crash.
Ever watch a NASCrash race at Martinsville or Bristol? Ever watch the Rolex 24? Too much rear bias = wreck!
There's a reason the manufacturers put smaller rotor one pot brakes on the rear. It's so the cars don't crash.
you don't even need a corner, just straight line panic stopping, or normal braking on a reduced friction surface (like a wet road)...when the rears skid,and the fronts are still turning, the tail comes around, violently.
unless you can do the extensive testing (and crashing) reqd to qualify your increased rear brake bias, DON'T do it..leave your rears ''under braked'' like all manufactures do.
look up the early '80's problem gm had with X-body (citations,etc) cars killing people due to rear brake lock-up, and that was with rear drums
Also, I think the Wilwoods are overpriced. Those movits look like a more rigid caliper with more swept area. Are they less than WW?
Right now no because the of USD to EURO exchange rate. I checked the rate yesturday and it was at .77euro cents for 1 USD. He also uses higher quality and stronger materials then wilwood. He will also paint caliper/hat in any color or nickel plate for a chrome look.
The prices posted on his usa site are the US "retail" I can get you all a few hundred off those prices if anyone is interested.
If you live overseas the posted price for a 6 piston setup is around 5000euros because of the taxes!! ouch
The DRM spring is already tested in the SCCA showroom stock series. And if you think the manufacturer knows best, why did they underbias the rears by 50%? The first rear disc camaros are even worse. I believe GM didn't even change the bias after losing the drum brakes.
I think I am going to stick with the C5 or Z-06 Upgrade for now....maybe something else latter down the road. Is there a differance between the C5 and Z-06 brakes? I heard there was but I am not too sure.
I believe GM engineered the car for the 90% of drivers who can't handle race car precision. It's just like downsizing the fronts on LT1 and later cars. Same size tires all around is great for neutral handling, yet they spoiled this setup to answer complaints from owners who don't want to pay too much attention to the car while driving. Little rear brake bias is SAFE for the 90% of drivers who need benign handling in these cars.
I will just do a search latter tomorrow to find whats the differance if any between C5 and Z06 brakes. I am mostly talking about proformance and if they have the same mounts.
