What size stall converter?
Old Aug 22, 2001 | 12:53 PM
DarkRose94's Avatar
DarkRose94
Default What size stall converter?
I'm running a 226/226 duration and .520/.520 gross lift on the cam and was wondering what size converter would be good to run with?
Old Aug 22, 2001 | 01:18 PM
jpee's Avatar
jpee
Default Re: What size stall converter? (DarkRose94)
A lot depend on duration, overlap, if its installed advanced etc...& rear end gear ratio,,,
I am running 3.73 & use a Vigilante 9" 2800 converter.. & drag race a lot, but the converter still locks up on the highway..
Be sure to get an aftermarket trans cooler to run with your stock one as a 2800 converter WILL cause the trans to run hotter..
Old Aug 22, 2001 | 02:03 PM
DarkRose94's Avatar
DarkRose94
Default Re: What size stall converter? (Red96Coupe)
So what about the coolier line going to the radiator, that won't do enough? I had plans on running a 3.42 rear end with a 700R4. I guess a B&M converters are ok and what about TCI's??
To What size stall converter?
