high idle
Old May 3, 2006 | 08:59 PM
GrtWht91's Avatar
GrtWht91
Default high idle
i installed the superram (plenum, runners, and manifold) along with comp cams 1.6 rockers and when starting up the car seems to being idle extremely high like around 1500-1800 rpm....any ideas on how to change this?
Old May 3, 2006 | 10:53 PM
goldeneye_vet's Avatar
goldeneye_vet
I'm going to bet you have a vacumn leak somewhere. Spray carb cleaner or WD-40 around the intake, runners, and TB to see if the idle increases. If it does than you have a vacumn leak, if not than you will have to dig deaper and hopefully somebody else chimes in to offer a hand. Good luck!
