Need hellp fast (alternator)
Old Aug 22, 2001 | 05:28 PM
89VetteWIP's Avatar
89VetteWIP
Default Need hellp fast (alternator)
Vette died on the way home today.
Need a quick cheat sheet on alternator swap (89 L98)
thanks all
Old Aug 22, 2001 | 05:36 PM
Kale's Avatar
Kale
Default Re: Need hellp fast (89VetteWIP)
Nothing to it, there's 3 bolts holding it on, if I remember right, plus the electrical connector. 5 minute job ;)
:bb
Old Aug 22, 2001 | 05:48 PM
89VetteWIP's Avatar
89VetteWIP
Cool... stupid. stupid question.. how do you release the tensioner
Old Aug 22, 2001 | 05:50 PM
Scoob's Avatar
Scoob
You need a 1/2" breaker bar. In a pinch I've just used a big stick to push it down enough to loosen the belt.
Old Aug 22, 2001 | 10:34 PM
jfb's Avatar
jfb
If you will look on the tensioner arm, you will see a 1/2" sq hole. Insert a 1/2"
drive breaker bar and use the breaker bar to rotate the tensioner arm so there is no tension on the serpentine belt. Then you can remove the serpentine belt and relax the tensioner.
Old Aug 22, 2001 | 11:24 PM
91Vette's Avatar
91Vette
You might want to get used to changing alternators. I just got my second one replaced in two years.
Old Aug 22, 2001 | 11:32 PM
89VetteWIP's Avatar
89VetteWIP
Thanks guys.. with nothing but a set of combo wrenches, a flashlight, and a 1/2" breaker, 12 Minutes.. God I LOVE my car.
Save the wave, and thank god for the forum
Old Aug 23, 2001 | 01:27 AM
GlockLT4's Avatar
GlockLT4
Since my post didn't get answered, if my alternator is putting out 89amps max, does it need replacing?? I get an SYS every once in a while at start up, and I think this is the cause. Battery was tested out fine.
Old Aug 23, 2001 | 01:58 AM
scorp508's Avatar
scorp508
1/2" breaker bar
10mm socket
13mm socket (or is it 15mm)
5 minutes of time
Old Aug 23, 2001 | 03:57 AM
GlockLT4's Avatar
GlockLT4
Default Re: (scorp508)
And if someone does an LT1, you need to have a T-50 torx, a 13mm and a 14mm socket, as well as the 1/2" for the tensior
[Modified by Glock'94, 1:57 AM 8/23/2001]
To Need hellp fast (alternator)
