Differences in C4 front Suspension
Old May 5, 2006 | 11:12 AM
GRX's Avatar
GRX
Default Differences in C4 front Suspension
Did a search but not much revealed. I know years ago reading on the various differences in the C4 front suspension throughtout the years but can't find my notes on them.
In the process I has hoping to get rid of my front wheel spacers (1985) I have installed that facilitate the zr1 rims not rubbing on the inner fender well.
I seem to remember 1988+ C4s not needing these spacers?
Old May 5, 2006 | 11:26 AM
vader86's Avatar
vader86
88 got a complete redesign of the front suspension based on information gleaned from the Corvette Challenge series. No parts interchange in front between the 2 suspensions (84-87 and 88-96), unless you want to do a complete rebuild of the front.
They were also responding to complaints about the ride harshness, and found they could soften the ride and maintain handling by altering the front swaybars (in geometry and size).
Wheel offset was also changed, from 38mm to 56mm for the 9.5" rim.
Old May 5, 2006 | 05:11 PM
GRX's Avatar
GRX
Not even the spindles?
Old May 5, 2006 | 05:21 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I'm pretty sure that at minimum that A-arms and splindles (and brake components) would have to be changed. I'm not sure if the same mounting brackets could be used or not. Someone will know, I feel sure.
Old May 5, 2006 | 06:01 PM
vader86's Avatar
vader86
bearings and balljoints will, outer tie rod ends i think are the same (inner isnt)
knuckle is different
To Differences in C4 front Suspension
