Which chip to BUY????
Old Aug 22, 2001 | 06:17 PM
KNCRSR5R's Avatar
KNCRSR5R
Default Which chip to BUY????
Hey guys......
Going to buy a chip for my carsoon.......which is the best for the buck?? Are there any problems that you nmight face buy running a cooler thermostat? Is there any thing that would need to be changed along with the chip so I wont ruin anything?? I find it hard to beleive that you can just plug it in and not affect many other things for the worse if they are not in pristine shape...or am I wrong??
Only mod so far is cut air box. By the way...do you have to change anything when you do that as well??
Thanx
Old Aug 22, 2001 | 06:55 PM
codyusa's Avatar
codyusa
CI 5-6-7-8-9-10 Veteran
Default Re: Which chip to BUY???? (KNCRSR5R)
Today, I ordered a chip from Ed Wright. It seems many forum members use his chip and are quite satisfied . Hopefully, the members are correct. I guess I'll find out.
Old Aug 22, 2001 | 09:09 PM
-=Jeff=-'s Avatar
-=Jeff=-
for the cost of buying a PROM from a Tuner.. you can buy all the gear needed to burn your own.. Assuming you have Diacom or such.
But if you just have a cut lid.. a PROM won't help much..
Old Aug 22, 2001 | 10:29 PM
KNCRSR5R's Avatar
KNCRSR5R
Ok then.........so what will help me get some good ponies and not break the bank?? Should I do something along with the chip also?? :confused:
To Which chip to BUY????
