Tired of Electrical Problems
I would look for a ground problem or a short. It could be intermittent, like insulation rubbed off of a wire that is shorting out sometimes. Inspect and clean the connections of all of the big wires that run between the starter, battery, and alternator, ground included. Make sure you have everything turned off and try connecting the ground wire to the battery, preferably in the dark or deep shadow. Look for a spark between the battery terminal and the connector as they get close to touching. You can even kind of tap the connector on the terminal a few times watching for any signs of a spark. That will tell you if you have a short. Unfortunately, it won't tell you where it is. You can always try pulling fuses one at a time to see if you can isolate it to a circuit. If you can't find a short or ground problem, then I would suspect voltage regulation next. If you can get the car started again, check the voltage at the battery while running. It should be around 13-14 volts. You can also check the voltage with a freshly charged battery in the circuit. It should be at least 12 volts. If it is below that with the car off, then you have a short that is dragging down the voltage. If it is too high with the car running then the voltage regulator isn't doing it's job. I believe most cars have the regulator in the alternator now. Since you have changed alternators, this seems unlikely to be the problem. Having made all those changes in such a short time leads me to believe that you have an intermittent short. I had one right where the hot lead goes into the alternator. The insulation had worn away where the wire rested on the edge of the valve cover. However, when that happened, there was no electrical power to the car at all. I am assuming, of course, that you are completely devoid of any electrical in the car at all.
If all or most of this is greek to you, ask some of your friends or car buddies if they might be able to help you out. It doesn't take too long or require much work beyond loosening a few nuts/bolts and maybe having to jack your car up. Usually, a dead battery after one month means you have a pretty good short or the alternator isn't working. What I used to do to check for a dead alternator is get the car running, then disconnect the positive lead from the battery. If the car died, it meant the alternator wasn't working. If it kept running, the battery was bad. If the battery measures 12 volts out of the car (or disconnected), it usually means there's a ground problem.
