1984 Vette interior lights
Old May 6, 2006 | 06:11 PM
HT1663WB's Avatar
HT1663WB
Default 1984 Vette interior lights
Hi guy's need a little help with interior light problem. 84 Vette interior lights time out when doors are closed but after there off for a couple minutes they will come back on stay on for a couple minutes flicker and then go out..this will go on until the battery dies. Also when i drive down the road sometimes when I hit a bump the interior lights flicker on and off. Any help would be great..Thanks, Bill
Old May 6, 2006 | 08:32 PM
champs65's Avatar
champs65
Hmm, I don't know if a courtesy lamp switch being loose or bad will cause this, but maybe it would be a good idea to loosen and tighten both of them to better ground them; see if this helps the problem.
Also, the courtesy light delay timer may be bad....its located behind the breadbox (on an 85) and is easy to bypass by jumping 2 wires in the plug once you get back there. Do a search for this, I can't remember which 2 colored wires they are, but the info is here...I've done it.
Just a couple easy ideas to help isolate your problem; hope it helps!
Old May 6, 2006 | 08:44 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Check the hatch pin switch. Maybe loose and/or out of adjustment. Hatch glass wiggle, lights come on.
Old May 6, 2006 | 09:47 PM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
Thats a good tip...you can even unplug it back there to keep the lights off ...I did that when I was using a hatch vent bracket and the button on top of the switch had cracked halfway off,causing an intermittent problem with the lights going on and off.
Old May 7, 2006 | 08:36 PM
84vette96's Avatar
84vette96
My 84 did the same thing. The timer for the lights went bad. I could get them to shut off by tapping on the passenger side kick panel. However they would come back on sometims. the timer is a small black box under dash on pass. side.
Old May 8, 2006 | 02:18 PM
84vette96's Avatar
84vette96
Jst wondering if you found your problum. if not I can look it up in service manuel.
Old May 8, 2006 | 04:16 PM
HT1663WB's Avatar
HT1663WB
I just had to run out and get a new battery. I'm going to check that box now and I'll let you know. I really appreciate the help.
Old May 8, 2006 | 04:52 PM
HT1663WB's Avatar
HT1663WB
Ok, timer is disconnected for the courtesy lights. I did a search for information regarding bypassing the timer but nothing came back.. Does anybody know how to do this? Thanks, Bill
Old May 8, 2006 | 05:09 PM
84vette96's Avatar
84vette96
I don't know how to bypass but GM still sold the timer 5 years ago.I think it fit other cars. I would try the dealer and find out if it did. Then a trip to the bone yard might pay off.
Old May 8, 2006 | 05:19 PM
84vette96's Avatar
84vette96
I gess we don't pay attention :o
Old May 8, 2006 | 05:22 PM
HT1663WB's Avatar
HT1663WB
I'll try the dealer tomorrow. Thank you again for all your help. Without the forum I'm sure it would have taken sometime to find my problem. Thanks again, Bill
Old May 8, 2006 | 05:23 PM
HT1663WB's Avatar
HT1663WB
Old May 8, 2006 | 05:32 PM
84vette96's Avatar
84vette96
No problum . I hope they still make the part. And I hope It's going to work for you
Old May 8, 2006 | 08:37 PM
HT1663WB's Avatar
HT1663WB
Got It! On the connecter, for the courtesy light delay, terminal A to terminal D (single white wire = A to double white wire = D) delay is now bypassed.
Old May 8, 2006 | 08:49 PM
84vette96's Avatar
84vette96
well that was cheaper than parts.
Old May 8, 2006 | 09:20 PM
champs65's Avatar
champs65
Paying attention now! Glad to hear it worked.
If I ever need to get back there again I'm SURE I'll knock off my jumper wire!
BTW HT1663WB, is your interior red? My black 85 has a graphite interior. Might be buying carpet soon and am considering a change to red. I think it might look good even to leave the seats graphite against a red carpet and console lid. What do you think?
Old May 8, 2006 | 10:44 PM
84vette96's Avatar
84vette96
I love the idea My cosin had 85 with red int. the black plastic and red every thing else looks great
Old May 9, 2006 | 10:24 AM
HT1663WB's Avatar
HT1663WB
my car has red carpet, black seats, black console and a black dash all the interior trim is also black including the door panels. If I could figure out how to post pics I could show you. I think the graphite would look good with the red.
To 1984 Vette interior lights
