OBDII - How to read
Old May 6, 2006 | 08:51 PM
DG'sVette's Avatar
DG'sVette
Default OBDII - How to read
Sorry guys. I had this info before but I lost it.
What pins do you short to read the codes & what steps to you take to read them?
Old May 6, 2006 | 09:06 PM
DG'sVette's Avatar
DG'sVette
Sorry guys. Jumped the gun. Got a little lazy. Found the directions.
Old May 6, 2006 | 09:24 PM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
You need a scan tool...is that the instructions you found?I never heard of being able to jump OBD2 codes with the paper clip style.
Old May 6, 2006 | 09:59 PM
aminnich's Avatar
aminnich
His profile says he has 95, which is OBDI, not obdII, so he can 'paperclip' it. OBDII started in 96.
Old May 6, 2006 | 10:07 PM
DG'sVette's Avatar
DG'sVette
Yep. Its OBDII style but its OBDI. Now I have the codes I just need to find out what they mean.
H48
H18
H15
Any ideas?
Old May 6, 2006 | 10:24 PM
Aggravated4life
95 was a hybrid year..you got the OBD1 terminal but the program was OBD2..at least most GM cars got that...my 95 van has the hybrid as well...
I cant paper clip it or at least I didnt figure out how.I just go to advance auto and they scan it for free there.Autobones wont do it anymore.
Btw I dont recognize those codes...the OBD2 codes Ive seen are usually P01080 or something...P0300,P0301,etc etc for example.At least on a scanner...lemme check something and get back.
Old May 6, 2006 | 10:31 PM
Aggravated4life
Dont know the codes that was posted,but heres a website you can put in your info and it will tell you.
http://www.autotap.com/codes.asp
Old May 6, 2006 | 10:59 PM
DG'sVette's Avatar
DG'sVette
Thanks guys. I found the codes in my service manual. It looks like I got these codes from trouble shooting my hard start condition. The codes are related to the MAF, Coolent Temp Sensor, & Injectors.
This has lead me to start my opti replacement. My engine is getting to much fuel & not enough spark.
Old May 7, 2006 | 01:25 PM
96GS#007's Avatar
96GS#007
So you get codes for the MAF, CTS, and injectors and instead of troubleshooting them you replace the Opti which has it's own set of codes?!
Old May 7, 2006 | 02:05 PM
DG'sVette's Avatar
DG'sVette
Here is the complete story
I've been chasing a hard start but it really wasn't that bad. I took it up to the goodyear shop to get the radiator flushed & filled. When I got it back the mechanic said that the coolant temp sensor & pigtail was shorting. He said it was a common problem on a 350.
Then when they handed over the keys I couldn't get the car started. We had to play with the MAF & injectors to get it going. The mechanic that help me get it going told me that the opti was going out.
So I'm suspicious if they got coolant on the opti & finished it off.
Now I got the car home & ordered a bunch of parts & am going to replace the opti & some odd ball components up front. It will probably take me 2 weekends & a couple of trips to the fridge.
Old May 7, 2006 | 03:07 PM
VenkmanP's Avatar
VenkmanP
Other way around. 94-95 vettes are OBD1 with the OBD2 connector.
They also have some OBD2 codes implemented, but you can't get those with the paperclip.
Old May 7, 2006 | 04:52 PM
Aggravated4life
Oopps..thanks for the clarification!
To OBDII - How to read
