What are these codes
Old May 6, 2006 | 09:38 PM
DG'sVette's Avatar
DG'sVette
Default What are these codes
Can anyone help me understand what these codes are?
H48
H18
H15
Old May 6, 2006 | 11:02 PM
DG'sVette's Avatar
DG'sVette
Found Them
H48 = DTC48 MAF Sensor Circuit
H18 = DTC18 Injector Circuits
H15 = DTC15 Engine Coolant Temperature Sensor
I have the service manuals but the exact letters were not matching up. I hope this is correct.
Old May 6, 2006 | 11:13 PM
bogus's Avatar
bogus
the H means History - it's a stored code. C would mean Current, as in it just happened.
I think the H means that it's happened a lot recently.
What year is your Corvette?
Old May 6, 2006 | 11:32 PM
DG'sVette's Avatar
DG'sVette
I've been chasing a hard start but it really wasn't that bad. I took it up to the goodyear shop to get the radiator flushed & filled. When I got it back the mechanic said that the coolant temp sensor & pigtail was shorting. He said it was a common problem on a 350.
Then when they handed over the keys I couldn't get the car started. We had to play with the MAF & injectors to get it going. The mechanic that help me get it going told me that the opti was going out.
So I'm suspicious if they got coolant on the opti & finished it off.
Now I got the car home & ordered a bunch of parts & am going to replace the opti & some odd ball components up front. It will probably take me 2 weekends & a couple of trips to the fridge.
Old May 7, 2006 | 12:54 AM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
How did you jump the codes to get them? I dont know the procedure for obd2 with the obd1 aldl...thanks.
Old May 7, 2006 | 03:31 AM
DG'sVette's Avatar
DG'sVette
Pin 4 & Pin 12
To What are these codes
