OK Fellas what gives!!
Old May 7, 2006 | 12:36 AM
Gold1986Vette420's Avatar
Gold1986Vette420
Default OK Fellas what gives!!
This is the chart it was Dynoed before the Accel DFI (speed density) and exhuast upgrade (3 Inch true duals with bullet cats and x pipe).
Hp numbers are way lower than expected...
some major tuning issues I am sure,
What I suspect is really bad wiring.
http://www.ttperformance.net/dyno/larry.jpg
Keep in mind this is with an unlocked converter.
Any ideas why its so low on torque and why the car seem too fall flat on its face at 5500? Check signature for mods. only about 800 rpms of clean dyno.
Old May 7, 2006 | 01:57 AM
bogus's Avatar
bogus
I would start with getting that converter to lock. An unlocked converter is not going to provide 100% power transfer.
Old May 7, 2006 | 02:03 AM
Gold1986Vette420
its a non lockup converter.
Old May 7, 2006 | 02:12 AM
Zix's Avatar
Zix
Well, it's hard to say. One thing I did notice though was that your AFR seems a bit lean, at almost 14:1, then suddenly goes rich to about 12:1. I'd be shooting for about 12:9, who did the programming?
Old May 7, 2006 | 02:26 AM
Gold1986Vette420
I am not sure what the deal is with the programming and thats the reason why I am switching to the accel dfi gen VII standalone.
It is a TPIS level 6 chip.
my question is: why does the motor seem to break up or lose power when it started to run rich.
This motor has pulled accidentally to 7900 rpm quickly in second gear (on playback tach) I cant imagine it doing that with the torque falling off at the rate that it does on that dyno sheet. My stock wiring is junk and the dfi should cure that.
shouldn't this motor peak hp about 6200 - 6400 rpm?
Old May 7, 2006 | 08:51 AM
bjankuski's Avatar
bjankuski
What are your cam specifications, and what exhaust were you running with this dyno chart?
Old May 7, 2006 | 01:12 PM
Gold1986Vette420
420 cube 11.28:1 compression
AFR 210 cc heads
4340 Eagle Stroker assembly assembly with 6" H beam rods
JE Custom Pistons
Cam is a TPIS 700-701 w/ 1.6 rockers
248, 248 @ .050
.659, .661 lift
110 LSA
The exhuast is TPIS 1 3/4 primarys into TPIS front Y then to Random Tech Cat , and dynomax ultraflow rear Y and Flowmasters (the whole system is 12 years old).
The cam should peak higher than 5500 with a port matched and cleaned up miniram right?
Why is it falling flat on the dyno when it pulls like crazy well past 7500 rpms.
If it is running rich then it isnt a fuel delievery problem.
Also wouldn't you think the torque would be a little higher than 340 at its peak?
Old May 7, 2006 | 09:24 PM
bjankuski's Avatar
bjankuski
AFR 210 cc heads
JE Custom Pistons
248, 248 @ .050
.659, .661 lift
110 LSA
I believe the problem you are having is the single 3" exhaust and single randam tech cat. A good friend of mine has a 396 mini ram engine with zz-409 cam and he dynoed his car with the cat and with a test pipe. With the randam tech hi flow cat he lost 48 RWHP from the test pipe. I believe your combination is being held up by the single cat, measure your back pressure before the cat, if it is higher then 2 PSI you are loosing significant power in the exhaust. If you have switched to true dual exhaust you still should measure the pressure to make sure your system is working correctly.
Old May 7, 2006 | 10:28 PM
tpi 421 vette's Avatar
tpi 421 vette
I picked up close to 25 rwhp and 40 rwtq going from a single 3" pipe with a gutted car to a single 4" pipe. I had to add 6-7% more fuel everywhere after the 4" exhaust.
Old May 10, 2006 | 12:10 PM
Gold1986Vette420
I should be getting my car back from TTP in New Jersey on sat the 13th. I am hoping to have a new Dyno sheet to post at that time.
They are changing my exhaust over to a dual 3" with bullet cats and a x pipe.
They are also installing a full manual valve body in my trans so I am hoping for a more complete dyno sheet next time around.
I also brought them a Accel Gen 7 dfi to install but they changed their mind about installing it as they said they are too busy to get into a "project" at that time. (they primarily tune LSx motors). And they don't normally deal with 20 year old cars.
Will keep you guys posted.
Thanks again for the info.
Larry
Old May 11, 2006 | 11:40 AM
Gold1986Vette420
Does anyone know who in the Poughkeepsie NY area would install and tune my accell gen 7 DFI?
TIA
Larry
Old Jul 26, 2006 | 12:11 PM
Gold1986Vette420
Default Update And Questions
Sorry for pulling this dead thread from the archives fellas.
UPDATE:
I finally got the Car back from the shop on the 15th of JULY and it still doesn't have a good exhaust on it. All they did in 3 months was a TCI full manual Valve Body.
I had them put the exhaust back to what I drove there with due to 3 month wait.
Should I go all out with the exhaust or leave it minus the CAT and add dumps?
What kind of mufflers flow the best with the least amount of noise?
I am thinking 3" mufflers and an xpipe duals. Does anyone know the CFM Flow and Decibel level of 3" Corvette mufflers?
I am in search of that magical 400 RWHP unlocked on a Dynojet.
It still has the stock MAF (minus screens).
Tuning is a mile off.
What should I expect from Tuning and Less Restrictions both intake and exhaust?
I have been tempted to run it in the 1/4 but the car runs a bit rough at the moment with the 20 year old computer running this beast.
To OK Fellas what gives!!
