Rear Sway Bar Size
Old May 7, 2006 | 10:04 AM
patdaddy's Avatar
patdaddy
Default Rear Sway Bar Size
My car is a 1996 Collector Edition, LT1. I want to replace my rear bushings with poly bushings. The build codes only identify the suspension as "Suspension System, Soft Ride". The sway bar is 15/16 inch in diameter which converts to 23.8 mm, but I haven't found that specific size listed for sway bar bushings! I see 23.6 mm at Eckler and 22 mm at Corvette Central. What is the correct size?
Old May 7, 2006 | 10:09 AM
Pete K's Avatar
Pete K
Sounds like 24mm. Slip a 24 mm open end wrench over the bar. If it fits nice, that is the number.
Old May 7, 2006 | 10:31 AM
vader86's Avatar
vader86
Its a 24mm rear bar.
Old May 7, 2006 | 10:47 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Standard suspension in the later years is 24mm rear and 26mm front.
Old May 7, 2006 | 12:08 PM
patdaddy's Avatar
patdaddy
Default Sway Bar Size
Thank you gentlemen. I do appreciate the help.
To Rear Sway Bar Size
