c4 weight
Old May 7, 2006 | 10:30 AM
rottwild95's Avatar
rottwild95
Default c4 weight
building a C4 track car and I am having a problem finding an aprox weight to pick the cam for my 400 sbc.
any one know?
Thanx Harry
Old May 7, 2006 | 10:45 AM
Sidney004's Avatar
Sidney004
My 1994 stock, full tank and 165# driver is 3600#
Old May 7, 2006 | 12:01 PM
NitrousSam's Avatar
NitrousSam
Default 1984 Weight
3200 lbs + or - for the 1984. Mike Antonics Corvette Black Book on page 133 claims the 1984 weighs 3192 lbs. The 84 is a bit unique because it doesn't have a lot of added weight features like ABS, air bag, traction control and so on. Your car should weigh even less if you are going to be using aluminum heads on your 400 engine because the 84 came with iron heads. There are lots of things you can do to remove weigtht from these cars.
Old May 7, 2006 | 04:36 PM
red L98's Avatar
red L98
i have an 1986 and its about 3100 with me in it
Old May 7, 2006 | 04:46 PM
black_89_vette's Avatar
black_89_vette
89 zf6
3250 with 1/4 tank of gas
Old May 8, 2006 | 01:45 AM
Cold_B's Avatar
Cold_B
My '96 LT4, with a full tank just filled, amp and 2 12's weighed 3360 without me.
Old May 8, 2006 | 11:42 AM
95NOSvette's Avatar
95NOSvette
1/4 tank of gas, without the front swaybar, and mines a spare tire deleted car from the factory.....Im at 3135 without me in it.......
Old May 8, 2006 | 05:18 PM
hardlight's Avatar
hardlight
track only or street/ocassional track?? you can pull several hundred pounds out if its gutted
Old May 9, 2006 | 01:43 AM
NitrousSam's Avatar
NitrousSam
You can remove more than 200 lbs pretty easily. There is also so much hidden weight under the hood that can be removed.
To c4 weight
