I give up...
Old May 7, 2006 | 11:11 AM
CMYC4GO's Avatar
CMYC4GO
Default I give up...
How in God's Green Earth do you get this friggin shifter **** off of this 6 speed transmission???? I've pulled the cap off the ****, and tried tugging on that little rectangular metal pin looking thing to no avail, and it will not budge. Next step is dynamite, unless somebody has a more productive method in getting it off.
I've got a purty new Hurst **** to go back on it, if I could just get the #$%& OEM **** off of it. TIA
Old May 7, 2006 | 11:18 AM
george4's Avatar
george4
Press fit. Vice grips and tap upwards with a hammer.
Old May 7, 2006 | 11:32 AM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Yep, that is about the only way to do it. You'll never pull it out. Get a small vice grips locked onto it, then tap up with the hammer on the vice grips
Old May 7, 2006 | 11:35 AM
CMYC4GO's Avatar
CMYC4GO
That did the trick. Thanks guys!
To I give up...
