fuel pressure
Old Aug 22, 2001 | 11:12 PM
Z-ZANY's Avatar
Z-ZANY
Default fuel pressure
Could someone please let me know the corect fuel pressure fo a 88 L98
Thanks in advance, Jim :confused:
Old Aug 22, 2001 | 11:42 PM
Midnite 88's Avatar
Midnite 88
Default Re: fuel pressure (88 ragtop vette)
Mine is at 44psi key on engine off. It drops to 39psi w/engine running idle.
I don't know if this is normal or not. I believe the manual says ... hold on let me get the manual.
Okay now I need someone to teach me how to use this flipping manual!!!!
It says "see chart in section A-7." I don't see a section A,B,C,D..... of any other lettered sections only numbered! :mad
Old Aug 22, 2001 | 11:53 PM
Midnite 88's Avatar
Midnite 88
Default Re: fuel pressure (Midnite 88)
Okay, here it is directly from the manual.
Fuel pressure, with pump running should be 40.5-47psi.
Start and idle engine at normal operating temp pressure should be lower by 3-10psi. :crazy:
That was almost too much work.
Hope it helps.
If you need, let me know and I'll scan and E-mail you this page.
Mike.
To fuel pressure
