Headlight Motors
Old May 8, 2006 | 07:56 AM
devilfish's Avatar
devilfish
Default Headlight Motors
My right headlight is acting wierd..
It wount open full or close full. Its not that the headlight Motor is keept running like it whas a bad gear or something. Is more like the headlight Motor is not running long enough to fully close or open.
I tried to adjust the end point with the "screw" on top of the motor, but no luck.
But if I tap the light switch on/off the headlight will eventually close or open. Its like its not getting any end point reference.
Where shall I start to look?
Old May 8, 2006 | 10:10 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
What year? There are two different C4 motor designs.
Old May 8, 2006 | 11:04 AM
devilfish's Avatar
devilfish
sorry.
Its my 1991
Old May 8, 2006 | 11:08 AM
Draven's Avatar
Draven
St. Jude Donor '14
Check to see if the headlight housing is hitting on anything. Mine has a very similar problem, because it hits on the coolant line that runs to the resevoir. Check for any rubbing. If it always gets caught in a predictable place, that may be the cause.
Old May 8, 2006 | 11:29 AM
Randy93's Avatar
Randy93
St. Jude Donor '06
The nylon bushings are going out, you have to take the the motor apart and replace the bushings. There is a Tech writeup on this, also do a search and you will find lots of threads on this.
Old May 8, 2006 | 11:30 AM
devilfish's Avatar
devilfish
the thing is that it always stay around 2cm from total open or total closed. If I adjust the "open" position with the adjust screw it wount close all the way, and if I adjust the "closed" position it wound be fully open.
Makes me frustraded..
Old May 8, 2006 | 11:32 AM
devilfish's Avatar
devilfish
Ok I thought that bad nylon bushings would make the headlight motor keep running even if the lights are fully up? But if not, thanks for the help. New nylon bushings it is.
Old May 8, 2006 | 12:35 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
The motor keeps running after the bushings are almost gone or gone, there is an inbetween stage were mine did what yours is doing. Also make sure the headlight bracket and linkage are not bent.
Old May 8, 2006 | 01:12 PM
rickneworleansla's Avatar
rickneworleansla
My headlights are also not fully opening on occasion and the motors are running longer than they should. Should I replace the gears at the same time as the bushings or is this not necessary. The plastic bushings are $5. The plastic bushings and plastic gear is $28. And the bronze is $60 with the plastic bushings. How many gears and bushings do I need to do both lights in my 95. Those prices were from the forum store in case anyone is wondering. http://www.zip-products.com/Corvette...5DB968D33C5EF1
Old May 8, 2006 | 01:30 PM
devilfish's Avatar
devilfish
Ok. There is no mechanical seting that I might try adjust? Something that might also be bad?
Old May 8, 2006 | 09:16 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
You should have marked the position of the bracket before you took it off. That is the only place to adjust the headlight, if they are not but back correctly then your light will not open and close properly. Check your alignment and check your bushings again.
Old May 9, 2006 | 09:06 AM
onedef92's Avatar
onedef92
Get the BUSHINGS, first. I'd say 90 percent of all 1988-96 headlight motor failures are due to worn bushings. Check the Tech Tips section on this Forum for the article that tells you how to remove them. You can also refer to this Corvette Fever article for help.
http://www.corvettefever.com/howto/33098/
Old May 9, 2006 | 10:22 AM
rickneworleansla
Thanks, will do. Oh, is it just the 3 I need or 6 for both sides?
Old May 10, 2006 | 12:56 PM
onedef92's Avatar
onedef92
You will need 6 bushings total. Three on both sides.
Old May 11, 2006 | 01:21 AM
kopbet89c4's Avatar
kopbet89c4
The hardest thing about replacing the bushings is hammering the roll pin out. #$%# this, #$%# that, then its easy from there.
Old May 11, 2006 | 01:42 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Great link. Who has the p/n, size, description for the home depot bushings?
Old May 11, 2006 | 12:41 PM
onedef92's Avatar
onedef92
You can use Home Depot bushings. The item number is 595609.
Replacement bushing are also available at your local parts store that sells "HELP" / "MOTORMITE" brand items.
They are the same for Ford truck window regulators. About $6.00-$8.00 per side at the parts stores.
Motormite parts # 74410.
Just tryin' to help a brother out...
To Headlight Motors
