Brake problem
Old May 8, 2006 | 01:15 PM
Wildcat1's Avatar
Wildcat1
Default Brake problem
My left front is getting more braking power than the right front. The rears are even. I just used a laser reader and got 210 degrees for the left front and 180 for the right front. It's been doing this for a long time. I always crack the front left rotor first. This is not causing any pull during braking, but I would rather the system work correctly no matter. Is this the nature of the beast or is there something I can do to even it out?
Old May 8, 2006 | 03:57 PM
bogus's Avatar
bogus
sounds like you have a hung up caliper.
Old May 8, 2006 | 05:29 PM
Wildcat1's Avatar
Wildcat1
What's the fix? Grease the sliders?
Old May 8, 2006 | 05:41 PM
bogus's Avatar
bogus
that might help. I am wondering if the pistons are a bit icky inside.
Old May 8, 2006 | 05:55 PM
Wildcat1's Avatar
Wildcat1
Probably. I may need to just buy new calipers. If I upgrade and buy grandsport calipers, can I keep using my pads and rotors? I have the standard suspension (brakes) etc. I was thinking the grandsport had the bigger rotors and pads.
Old May 9, 2006 | 08:12 AM
runner140*'s Avatar
runner140*
Its not too difficult to do a rebuild.
Old May 9, 2006 | 08:56 AM
pcolt94's Avatar
pcolt94
Possible flex line to wheel caliper starting to close up, reducing pressure.
To Brake problem
