Half shaft noise
Old May 8, 2006 | 11:36 PM
Harry G's Avatar
Harry G
Default Half shaft noise
Have a creeking noise, that appears to be coming from the Driver's side half shaft. Freinds have told me it sounds like u-joint, maybe needle bearings? Is the u-joint, spindle, rear bearing, not sure. Any sugguests and or hints in remove/replace for this type of a problem? Any recommendations on parts(brands) on bearings or u-joints?
Any help greatly apreciated.
Harry G
Old May 8, 2006 | 11:41 PM
scorp508's Avatar
scorp508
Do not get brute force u-joints.
http://personal.tmlp.com/scorp/vette/images/ujoints
Old May 8, 2006 | 11:42 PM
86PACER's Avatar
86PACER
I had that. Pour some motor oil into an empty spray bottle. Get under the car and spray some motor oil onto the 4 half shaft u-joints. Get in the car and drive. If the noise went away or it changed, it's the u-joints.
Old May 9, 2006 | 12:48 AM
newbecorvetteguy's Avatar
newbecorvetteguy
If you do the job yourself, the instructions in scorp508's post are good, only don't remove the one pointing to the camber bolt. Remove the bolt on the other end of that link instead and you won't have to worry about the adjustment.
To Half shaft noise
