Pulley Help, Please
Old May 9, 2006 | 06:34 PM
redsvette's Avatar
redsvette
5th Gear
Default Pulley Help, Please
We replaced the alternator in my "85" and now we have a chirp. We think it is the bearing in the tensioner. What is the best way to remove the tensioner? Also, a diagram for the "85" pulley system would be appreciated. Thanks in advance for your help.
Old May 9, 2006 | 10:57 PM
geezel's Avatar
geezel
The tensioner comes off real easy. Just back out the 14 mm bolt in the center. I just happen to have a nearly new Delco tensioner off my 86 that I'll let go for real cheap if you need one. Send me a PM if interested. The belt routing diagram should be on top of the radiator or on the hood just above the radiator.
