1990 Base Timing/NO Start
Old May 9, 2006 | 08:41 PM
90Conv's Avatar
90Conv
Default 1990 Base Timing/NO Start
Thanks to all that responded to my question last night. I decided that a little extra advance would be a good thing. Here's my problem now. When I unplug the ECM from the distributor (large multi pin connector behind distributor), the car will not start. It doesn't give any attempt. It just turns over. I put a timing light on a plug wire and did see that I am getting spark. It appears to me that when I unplug the distributor I disable the injectors. As soon as I connect the plug, it starts up instantly. I thought perhaps the base timing may be way out so I tried rotating the distributor off of the original mark while i cranked. I got nothing. It appears to me that I am getting no fuel. Okay I do have an Autoxray scanner. Is there some kind of criteria that would let me time it on the fly with the car running? If the injectors are disabled is there some means of jumpering them on? Thanks again
Old May 9, 2006 | 08:57 PM
RRT vette's Avatar
RRT vette
First thing to check is the injector fuses. On my 86 I can disconnect the EST and crank my car. You can also crank the car and then disconnect the EST. You are sure it was the EST right? Once the EST is disconnected the ECM can't control timing and then you can set base timing.
Old May 9, 2006 | 09:03 PM
tigmaned's Avatar
tigmaned
the EST wire is brown with a black stripe. you should see it from the drivers side of the engine bay. near the brake booster, not on the cap. get the car warm first, set up your timing light then do like the sticker on the rad says. my 1986 say 6 degrees in drive.
Old May 9, 2006 | 09:10 PM
90Conv's Avatar
90Conv
The plug I disconnected is on the back of the distributor. It is a large flat plug with 4 wires. The wires on the cap were left plugged in. I know it is not a fuse because when I reconnect the plug, all is well.
Old May 9, 2006 | 09:25 PM
mseven's Avatar
mseven
That plug is not the EST. If you are doing base timing, the plug (est) is in the harness that runs between the brake booster and the valve cover against the firewall. It will be a single brown w/blk.stripe wire in a weather pack connector.
Old May 9, 2006 | 09:34 PM
90Conv's Avatar
90Conv
I just ran out in the garage. I noticed a large bundle of wires behind the brake booster with a wire and plug coming out of it and tie wrapped along its side. The wire is a light brown almost beige with a black stripe. Could that be it or should I look some more?
Old May 9, 2006 | 09:35 PM
RRT vette's Avatar
RRT vette
Sounds like you unplugged the distrubitor to ecm. The EST is a single wire as described above.
EDIT: yes that should be the one!!
Old May 10, 2006 | 01:21 PM
90Conv's Avatar
90Conv
Thanks for all of the help.
To 1990 Base Timing/NO Start
