Rear gearing?
Old May 10, 2006 | 11:17 AM
RAGOVET's Avatar
RAGOVET
St. Jude Donor '05
Default Rear gearing?
I have a 95 VERT, stock 3.07 rear differential. What are the options and associated advantages/disadvantages of changing the rear gear ratios. Any info would be appreciated.
Old May 10, 2006 | 11:40 AM
vader86's Avatar
vader86
On an LT1 you'd get at least .2-.3 if not more (depends on driving skill) in the 1/4mi, it'll feel like a whole new engine.
Downside would be mileage losses on the hwy, but 3.54 should be a nice choice and not cost you more than a couple mpg on the hwy at most.
If the mpg losses scare you away, a torque converter would give about the same gain in ET, but no loss of mileage.
Old May 10, 2006 | 01:16 PM
95NOSvette's Avatar
95NOSvette
IMO, For an automatic, a 3.73 is about perfect..the acceleration difference from what you have now is really not describable(it's that drastic)....Like was mentioned, a bit less gas mileage on the highway, but about the same around town, Iv'e had some cars that actually got better mileage with (stop and go driving) after the gear..........with an otherwise stock car , with dragradials so that you would have some traction, you could drop over a half second from your quartermile times(seen it so many times)......and even more of a gain with the right converter selection...(with traction)....
Old May 10, 2006 | 02:03 PM
RAGOVET's Avatar
RAGOVET
St. Jude Donor '05
OK. One question .. Assuming my 3.07 stock differential is a D36 and to go to the 3.54 or 3.73 would need the D44, do i also need a different drive shaft?
Old May 10, 2006 | 02:09 PM
jksr1's Avatar
jksr1
I TO WANT TO GO WITH THE 3.73,SO IF YOU GO WITH THE 3.73 PLEASE GET BACK TO ME. AND TELL ME IF YOU LIKE THEM OR NOT.
Old May 10, 2006 | 02:26 PM
95NOSvette's Avatar
95NOSvette
Nope, you can (and I would recomend as far as what "brand" gears) get a "precision" brand gear for your dana 36......Now, If you have extra money to spend(a pretty good chunk), go with the Dana 44 for tha added strength..but with doing that, you would then need the drive shaft from a (dana 44)manual trans car, as well as the center torque beam from a (dana 44) car.........
Old May 10, 2006 | 02:41 PM
vader86's Avatar
vader86
You dont have to upgrade to D44, they make the 3.54/3.73 for yur D36.
You dont need a new driveshaft.
Old May 10, 2006 | 02:47 PM
RAGOVET's Avatar
RAGOVET
St. Jude Donor '05
COOL> thanks.
Old May 10, 2006 | 09:18 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
If you drag race, pick a ratio that will put you at the top of your 1:1 gear in the quarter mile. (auto = 3rd, stick = 4th).
If you are concerned about highway cruising and mpg, pick a ratio that'll give you an acceptable rpm in overdrive at the speeds you drive.
Old May 11, 2006 | 08:55 AM
RAGOVET's Avatar
RAGOVET
St. Jude Donor '05
Interesting. I assume that the increase in RPM that I would run at , if I were to increase my rear gear ratio, would be portional to the ratio of the new gear to old??? In other words , if I go with a 3.54 rear gear, then the increase in RPM I would see would be 3.54/3.07 or a 15% increase. If this correct? Anyone know...? If I went with 3.73, it would be a 21% increase in RPM? I believe that at 70 mph in OD, I run at about 2000 rpm, so this would increase to 2200 for 3.54 and 2400 for 3.73. Is this proper interpretation?
Old May 11, 2006 | 11:59 AM
RAGOVET's Avatar
RAGOVET
St. Jude Donor '05
In addition to the question on RPM/MPH vs rear gear, I have a question on changing the rear gear and the computer control module for the A4 transmission shifting. Does changing from my stock 3.07 rear gear to a higher gear, require that I change the computer programming to reflect this for transmission automatic shift points???
Old May 11, 2006 | 12:22 PM
conv90's Avatar
conv90
Shifts?
same rpm.
different speed.
If you adapt the speado gears (to read the new correct speed) you will have the TC lockup at part throtte coming later if you see the rpm and at the same speed as before.
If it was using to lock at say 1800 rpm at 45 mph... now it will be at 45 mph at 2200.
(I used random speed and rpm for the example....)
-Beppe-
Old May 11, 2006 | 12:24 PM
CentralCoaster
Something like that.
Or calculate it. Pick 26" for tire diameter if you don't know any better.
MPH = RPM x TireDiameter / TrannyGear / RearEndGear / 336
RPM = MPH / TireDiameter x TrannyGear x RearEndGear x 336
Old May 11, 2006 | 12:39 PM
tequilaboy's Avatar
tequilaboy
With a 4L60E, shift points are set as a function of tps and mph for each gear. (At least that's how my 95 K1500 with pcm 0D works.)
The shift points will need to be reprogrammed to occur at lower speeds to maintain the desired shift rpm. You can scale the tables by the old ratio/new ratio.
Old May 11, 2006 | 02:04 PM
95NOSvette's Avatar
95NOSvette
Part throttle yes.......but full throttle goes by engine RPM
Old May 11, 2006 | 02:33 PM
RAGOVET's Avatar
RAGOVET
St. Jude Donor '05
OK for a 1995 A4, if I were to get the new 3.54 or 3.73 gears for my D36 (replacing the stock 3.07) what do I need to reprogram the computer??
Old May 11, 2006 | 04:23 PM
vader86's Avatar
vader86
hypercrap will do it
To Rear gearing?
Old May 17, 2006 | 03:07 PM
RAGOVET's Avatar
RAGOVET
St. Jude Donor '05
I am told that they do NOT make the 3.54 or 3.73 for the 3.07 D36 carrier but only for the 2.73 D36 carrier???
Old May 17, 2006 | 03:38 PM
rickneworleansla's Avatar
rickneworleansla
I also want to know how this works out. I have the same gear 3.07 with an auto trans. The difference is that I have a 2800 stall Torque converter and have a problem now getting traction on the launch. I know this would be solved if I got stickier tires but it's a daily driver and I have no way to store or get extra tires to the track which is 1.5 hours away. I wont give up my tires good wet traction. It's saved my *** too many times.
Old May 17, 2006 | 06:17 PM
427t-top's Avatar
427t-top
I have 3.73's in my d36 so they do make them
