Hate to ask a dumb question!
Old May 10, 2006 | 02:05 PM
93cruiser's Avatar
93cruiser
Default Hate to ask a dumb question!
But here it goes. Where is the diagnostic connector on my 93 vert? I need to check for an intermittent code. Thanks for any help.
93cruiser
Old May 10, 2006 | 02:10 PM
RFDrpm's Avatar
RFDrpm
There are no dumb questions, just uneducated people looking for anwsers.
Its under the driver side dash closest to the trans housing.
RRT vette's Avatar
RRT vette
Under the dash on the drives side.
Old May 10, 2006 | 02:11 PM
Z~max's Avatar
Z~max
look under the drivers side of the dash just above where your right knee would be while driving. It is a trapazoid shaped connector.
Old May 10, 2006 | 02:22 PM
93cruiser's Avatar
93cruiser
Do you have to remove the under pinning cover to see it?
Old May 10, 2006 | 03:17 PM
swifty's Avatar
swifty
Nope . . . it's hangin' there b.a. naked!
Old May 10, 2006 | 04:41 PM
93cruiser's Avatar
93cruiser
Okay, I stuck my head all the way to the brake pedal and accelerator. No sign of the connector. I really do know what it looks like too. I have seen many diagnostic connectors in my time. The dash on my 93 is completey covered on the underside. I have removed the carpeted section but that revealed nothing. Can anyone send a pic of where I should look. Thanks in advance for your help.
93 cruiser
Old May 10, 2006 | 08:38 PM
RRT vette's Avatar
RRT vette
It should be here. It might still have a black diagnostic cover over it. You should be able to find it where the carpet ends on the bottom side of the dash as described above. It' about 1 1/2" x 1 size.
Sorry no pics
Old May 10, 2006 | 08:57 PM
93cruiser's Avatar
93cruiser
Thanks, I will remove the panel again. I know it is right in front me.
Cruiser
Old May 10, 2006 | 08:59 PM
bogus's Avatar
bogus
it's right above your right knee. Where the carpet and the plastic join.
C4 Guru - Reading CCM Codes
I have been told I have a typo in it... I just haven't had a chance to fix it! oops...
Old May 10, 2006 | 10:34 PM
RRT vette's Avatar
RRT vette
Cruiser
The panel doesn't have to be removed. Take another look.
Old May 11, 2006 | 07:30 AM
runner140*'s Avatar
runner140*
Real close to your right knee....
Old May 11, 2006 | 07:50 AM
tomtom72's Avatar
tomtom72
St. Jude 15 Year Donor
Active Streak: 90 Days
St. Jude Donor '08 thru '26
The color of the cover hides it very well if the lights are not on in the footwells. The plug is covered and on the face of the cover in my 90 it says "Diagnostic Connector" or "ALDL Connector" or something like that....it's been a while since I found it and I didn't find it quickly in a dark garage....it's about 1" x 3" so if it's dark you might miss it like I did the first lookie.:o
Follow the carpeted knee bolster, hush panel, from the dash down to the bottom edge on the right side of the steering wheel and your hand will get to the edge of the hush panel and it should be somewhere along that edge between the trans hump and the steering wheel.
Old May 11, 2006 | 07:56 AM
884jani's Avatar
884jani
like everyone has said, just above you knee on the right side. Sitting in the drivers seat you can almost see it but if you reach down with your right hand under the dash you should be able to feel it. right there in the front not too far back. kinda looong oval shaped, black plastic and if the cover is removed you should see pins inside of it, get a flashlight.
good luck,
Old May 11, 2006 | 09:01 AM
pcolt94's Avatar
pcolt94
Well... On my 94 its right above the gas pedal about 6 inches or so and attached to the bottom of the dash assembly (padded kick plate). It kinda points slightly downward.
Remove nothing, get your head down there with a flashlight, look for wires to a connector. Or if someone removed it they could have shoved it up high into a pocket where the wires are coming from. If there is really no connector mounted stick your hand up there to see if something will pull down GENTLY. Good luck.
Old May 11, 2006 | 01:26 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
If you do, consider yourself blessed. Many C4s came from the factory sans the connector cover and you'd shet yourself if you knew what MAM charges for those *****!
To Hate to ask a dumb question!
