sun visor
Old May 11, 2006 | 02:26 PM
zoro's Avatar
zoro
Default sun visor
Passenger side doesn't want to stay put.
Anything that can be tightened or is replacement the only option?
Old May 11, 2006 | 03:16 PM
IrishJoker's Avatar
IrishJoker
Take your top off and tighten the bolt that goes to the arm of the sun visor.
Old May 11, 2006 | 03:22 PM
geezel's Avatar
geezel
On my 86 there is no bolt on the arm to tighten the spring mechinism, it's a compression fit washer with barbs into a groove on the shaft. I don't know why as the shop manual shows a bolt there...
Old May 11, 2006 | 06:43 PM
zoro's Avatar
zoro
I should have been clearer. The movement between the mirror and the side window is fine. The visor tends to rotate downwards. I was originally going to say my visor won't stay up but didn't want to get any Viagra jokes.
Old May 12, 2006 | 05:05 AM
86PACER's Avatar
86PACER
I have the opposite problem. Mine's a little tight flipping it down and up. Maybe taping a layer of duct tape around the visor shaft will tighten it against the visor recess hole.
To sun visor
