i have here the accel superram intake for my 91vette but i didnt find the accel base ACC-74197 that i think,its that i need.
does anyone can tell me about gains on the superram with stock base manifold vs accel manifold???
is it worth it??
who has it on stock,cause i heard that is no longer available from accel!!
is it worth it??
Thanks!
It is available, but at this time they are backordered. I have three complete SR manifolds on order. At this time there is no date for delivery, not sure of what the problem is. They did have an issue with the current or past foundry where they were being casted. Your other option is to use a Edelbrok or a TPIS intake. Or you can attempt to port the GM unit. You would be leaving several Hp on the table if you were to use the stock manifold.
what are the differences between those edelbrock,tpis and the accel???
are those three the same just the brand different??
how many hp's do i lose with the stock manifold?
