Do a search of 'wheel bearing torque' and you will find everything you need. If you mean the spindle nut I think it is 164 ft lbs. Dial indicator tolerance is .001 to .005.
He says front so it's not going to be the spindle nut torque. I think he's talking about the 4 hub-to-knuckle bolts. I looked in my shop manual, and it does not show a torque spec for that fastner.
Yeah aminnich I did the search thing an could not find what I looking for. so I called NAPA his first question was did I buy them there. I said no he told me it was 76 ft. lbs. I also call CAR QUEST a female told me it was 57 ft lbs. also called AUTOZONE where I purchased them and was told it was 46 ft. lbs so I thought I try here and I got DO A SEARCH. Yes 86 pacer I am talking about the 4 hub bolt's THANK YOU SIR. and z-max you are correct it is 46 ft lbs. THANK YOU SIR
PS: My next purchase will be a shop manual
FYI: Look for one at a car show, it may prove to be cheaper. I think I paid a little over a hundred from the dealer, but that was with our shop discount. There is two books also, one mechanical and one for the electronics.
How odd, I did a quick search and found it almost immediately, BEFORE I suggested you do a search. Figured if I found it that easy so would you. Oh well, as long as you got what you needed. Good Luck with it now.
[QUOTE=aminnich]How odd, I did a quick search and found it almost immediately, BEFORE I suggested you do a search. Figured if I found it that easy so would you. Oh well, as long as you got what you needed. Good Luck with it now.[/QUOTE
yeah am???? I did and found 66 ft.lbs I had 4 different numbers was just looking for a QUICK ANSWER from the experts on this wonderful forum. I LOVE THIS PLACE.
