Stupid SuperRam runner to plenum bolts...
Old May 14, 2006 | 01:26 AM
kopbet89c4's Avatar
kopbet89c4
Default Stupid SuperRam runner to plenum bolts...
I'm taking off my SuperRam and swapping over to another intake due to persistent vacuum leaks. This @$%*ing intake apparently has massive vacuum leaks somewhere. I proved this with the propane gas trick. Sure changed the idle when I sprayed it under the plenum.
The removal of this intake will be much more troublesome because I don't have my knowledgeable good friend to help me out. In fact all are plenum-runner bolts are loosened but one. Its the one where the wiper motor and brake booster vacuum port is. How the hell do you get this off without taking the whole car apart?
Old May 14, 2006 | 02:27 AM
USAsOnlyWay's Avatar
USAsOnlyWay
In an earlier post you said you had no pipe-plugs in the two large holes (for EGR I think) in the bottom of the superram plenum.
Did you have something hooked up to them...or as you alluded to, are they just open and sucking in air
Cause' that will do it...
Old May 14, 2006 | 02:39 AM
goldeneye_vet's Avatar
goldeneye_vet
Put those pipe fittings in and see how it runs. If those are missing you found your leak. Big waste of time IMO is you are swapping out this intake for another when chances are you found the problem.
Old May 14, 2006 | 08:06 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
The lack of the 2 pipe plugs is not the cause. There is no outside air there, just the EGR circuit. I don't even know why the put those holes there.
Why not just tighten all the bolts.
Old May 14, 2006 | 10:02 AM
Red Tornado's Avatar
Red Tornado
unless you're running a higher duration cam, i have no idea why you opted to put on the SR intake to begin with; its a big mismatch with the stock cam, you need about 2 full steps up in duration. and then you've got your stock heads......
Old May 14, 2006 | 10:05 AM
85vet's Avatar
85vet
Cruise-In V Veteran
I either took off the distributor cap or took out the distributor to get to that d*mn bolt. You have to access it from the opposite side. It has been awhile.
Old May 14, 2006 | 10:12 AM
Pete K's Avatar
Pete K
Much easier without the cap. A small ratcheting bix wrench is worth having too. Speeds up the process.
Old May 14, 2006 | 10:23 AM
tequilaboy's Avatar
tequilaboy
It may be leaking at the passenger side runner to base, where the gasket slot is cut very close to the edge of the runner flange.
I used some faststeel epoxy to build up the top of the runner flange to get a larger sealing surface, to reduce the chance of leaking here.
This can be a problem on both sides, as there were some bad gaskets made with the slot too long. Hopefully you have the corrected gasket.
One thing to consider, you could just enrichen your tune to compensate for the extra air introduced via the vacuum leaks. It shouldn't be a huge volume of air flow, maybe a couple grams/sec.
Or you could stick a big cam in it that won't make much vacuum. This should help to reduce leaks.
Old May 14, 2006 | 10:42 AM
kopbet89c4's Avatar
kopbet89c4
Well, it still stalls and idles rough, even if my EGR is already blocked off. My vacuum stays steady at 20" and when on a hot long idle, it will drop to about 15" and still idle, but with a pop/miss here and there. Then when I push the pedal, it would just cut out like I stopped accelerating. Then vacuum would be 5" when it idles rough at 400-500 rpms. When vacuum builds up again, it will idle normally again as soon as vacuum gets up to at least 12". I have observed this whole trend with my handy vacuum gauge taped to the windshield while driving. Car seems to drive fine when I'm on a steady cruise at 70 mph where there's enough vacuum.
Old May 14, 2006 | 11:38 AM
tequilaboy's Avatar
tequilaboy
The rough running and stalling should still respond to tuning, although the presence of vacuum leaks can complicate things.
At very low rpm, the load variable goes up which results in a very rich mixture making things worse. The only real solution is IAC, mixture and spark tuning to prevent the low rpm situations from occurring. Shouldn't be a problem for an auto trans car, since you'll never be lugging at 400-500 rpm.
You could also lean out the low rpm portion of the basic pulse width table to compensate for the falsely high load. MAF calibration plays a role here also, with the kick up in the table making things worse.
I've been working similar issues with my own SR.
Try and get ahold of Alvin.
Curious: What intake would you use to replace the SR if you go that route? as there aren't many alternatives.
Old May 14, 2006 | 11:50 AM
Ramanstud's Avatar
Ramanstud
we've all been there, done that.
One time I had a massive leak (the "will barely idle" kind) and it boiled down to my getting two of the lower runner-to-base gaskets REVERSED. They're very similar and easy to overlook if you're not careful.
You'll want to double check all vacuum lines for splits or cracks, and to make sure there aren't any "free ends" laying around. The SR is a PITA sometimes and thus it's easy to yank and pull on things to break them loose.
Is your EGR valve sealing? if it's stuck open, that could also cause your problems.
Instead of propane, use WD40 or sensor-safe carb cleaner - this way you can spray it on various mating surfaces and areas to actually locate the area of the leak (IMHO more accurately than propane... and you don't have to worry about singing off your eyebrows in the process).
Good luck, mang!
Old May 14, 2006 | 12:42 PM
USAsOnlyWay
But he eliminated EGR, I assumed this meant he didn't have anything connected to them, as he stated in another post. I hope I am wrong.
Old May 14, 2006 | 12:47 PM
scorp508's Avatar
scorp508
Its really not THAT bad once you've done it once. It gets more flack than it should. Have the right tools ready and run a tap through the pizza box to clean up the castings and you will be shocked how easy it becomes.
Old May 14, 2006 | 12:50 PM
cv67's Avatar
cv67
St. Jude Donor '05
Id get someone who is a really good wrench to seal that SR up properly, throw that adjustable MAF in the trash and replace it with a Bosch. Reset your IAC, tps.
Bet the car runs fine after that.
Old May 14, 2006 | 04:39 PM
kopbet89c4's Avatar
kopbet89c4
Yeah, its the kind of stalling you get when the car is accelerating from a stop sign and just quits. Yes, it still would be idling, but roughly with the vacuum very low. When the car is idling this way, the engine will stall out when you press the accelerator. It kinda felt like my MAF problem I had a year ago, BUT the weirdest thing about my problem is that there are no codes that popped up.
The alternative intake that I was considering was a TPiS 1 piece Mini Ram intake. Less vacuum leaks to wory about. I'd also be swapping the cam as well since I'll be suffering a loss of low rpm torque.
Old May 14, 2006 | 04:41 PM
kopbet89c4's Avatar
kopbet89c4
It felt like it was easier to install the SuperRam intake but I'm just starting to get tired of all the vacuum leaks that it is starting to have. Yes, with a MiniRam, I'd also like to try a cam a little hotter than stock to make full use of the intake.
To Stupid SuperRam runner to plenum bolts...
