New setup shakedown runs.....
Old May 17, 2006 | 10:06 AM
Matt383's Avatar
Matt383
From: 2003 Points Champ Great Lakes Corvette Challenge; 2006/2007 Winner MSD True Street
Originally Posted by ski_dwn_it
MAtt,
I machined and assembled the spool that corky is running. It was done with the same process as mine.
Corky, you will need to sell him the stub axles as well remember, since they are pinned specifically to that spool. Therefore you will need to get some replacement ones, which is not a show stopper. Just something to keep in mind. Or, Matt you could send me your entire D44, I could cryo it for you at my fathers shop, and pin your existing stub axles to match corkys spool.
It all can me done, and will make your D44 MUCH MUCH stronger than the stock carrier/condition.
COOL!
I am doing some test n tune this week end.
What are we looking at a turn around on this?
Matt383
Old May 17, 2006 | 07:18 PM
farscape1a's Avatar
farscape1a
...you could send me your entire D44, I could cryo it for you at my fathers shop...
Hi Jesse. how much is it to do this? that's something i might be interested in. thanks!
Old May 18, 2006 | 09:09 AM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In IV Veteran
Cruise-In V Veteran
MAtt,
jesse remember my machine shop guru down here did all the machineing work on my spool and your dad drilled the holes for the bolts at his work
Old May 18, 2006 | 09:15 AM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In V Veteran
Originally Posted by Matt383
COOL!
Matt383
matt the spool is a drop in all you will have to do is take your stub axles and the spool you get from me to a competent machine shop and counter sink a hole in each stub axle to corespond with the drilled hole in my existing holes that are in the spool
if you buy a spool out right you would need the spool narowed a tiny bit and the bearing journel turned down to the saME SIZE THAT YOUR CARRIER IS NOW ITS NOT TO BAD OF A PROCEDURE PROBALLY A DAY AT YOUR LOCAL MACHINE SHOP
Old May 18, 2006 | 09:33 AM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Right, I just did not want you to forget that the stub axles would need to be replaced on yours or his redone.
The process is not that bad, once you see how it needs to be done. But I went through 3 revisions/installations of the entire rear before we got it right.
Old May 18, 2006 | 04:31 PM
red L98's Avatar
red L98
it took me 2 installation to get the spindles from walking out with no luck .
Old May 18, 2006 | 05:38 PM
comp's Avatar
comp
waitin' to hear the #'s on a prep'ed track and your finale tune,,congrats
