Header install Pictures
Old May 17, 2006 | 12:21 PM
96lt4c4's Avatar
96lt4c4
Originally Posted by 95wht6spd
Where did you get the band clamps and the headers extensions?
So you didn't get new bolts, but used the same one's that were on the manifolds? I am going to use ARP bolts, I won't have a problem with the accessories will I?
Yes because some of the factory bolts have studs coming off the ends of them. They are used for suport brackets.
Old May 17, 2006 | 03:59 PM
skateparkdave's Avatar
skateparkdave
St. Jude Donor '05-'06
Originally Posted by GlockLT4
Nah, i still get around 23 on the highway
Originally Posted by TM-96CE
Gas mileage on the street will drop because you find yourself nailing the throttle more often. But I still averaged 25.9 mpg on a 1000 mile round-trip to Oregon..... and that was with me doing 80-90mph the whole way.
Really?? With 4:10's?? Well, I guess I stand corrected. I have a friend with an F body LT1 who lost major fuel economy on the highway when he went to 4:10's only to gain about .6 in the quarter mile. I guess he did something wrong.
Old May 17, 2006 | 09:16 PM
95wht6spd's Avatar
95wht6spd
So what are others doing about the accessory mounting if they are usign ARP bolts and not the original?
So if you use no cats you have to have simulators and not the regular O2 sensors even with tunning?
Old May 18, 2006 | 07:52 PM
95wht6spd's Avatar
95wht6spd
ttt
Old May 18, 2006 | 10:22 PM
G-Sting's Avatar
G-Sting
There is a page for Stainless Works LT Header install on the stainless works website. Maybe the instructions there can answer some of your questions. Hope it helps.
http://www.stainlessworks.net/cart/i...STRUCTIONS.doc
BTW, Nice work on your headers, Bardstown!!
Old May 24, 2006 | 07:54 PM
95wht6spd's Avatar
95wht6spd
[QUOTE=96lt4c4]Yes these are TPIS. Great set of headers. They allow you to reuse all of your factory bolts, which you need on the drivers side for alternator and AC supporting arms. I had to weld header extensions to the factory pipes to hook everything up. The extensions will slip over the end of the header then you just use a stainless band clamp.
How long of an extension did you need from headers to stk exhaust, and what size pipe for extensions, 3"?
I am going to have the same set-up soon.
Old May 26, 2006 | 09:27 AM
96lt4c4's Avatar
96lt4c4
[QUOTE=95wht6spd]
I bought 18" header extensions which were a little long, yes 3"
