'88 tappered plug or not?
Old May 15, 2006 | 11:59 AM
Aardwolf's Avatar
Aardwolf
Default '88 tappered plug or not?
I'm having trouble picking up the right plug. Some of the plug books list a tappered plug and some don't.
Old May 15, 2006 | 12:12 PM
rick lambert's Avatar
rick lambert
Well, if you're using ACDelco..my favorite, the plug number is 41-629. You can also visti their web site.
Old May 15, 2006 | 12:24 PM
Aardwolf's Avatar
Aardwolf
Is that a tappered plug? Or normal, with the washer?
Old May 15, 2006 | 12:45 PM
xflagz51's Avatar
xflagz51
I've got a '90, L98 with aluminum heads and the spark plug specs are as follows. 5/8" hex, 14MM thread, 3/4" reach, std gasket seat, the AC spark plugs use a projected tip. The cast iron heads are using the same spec accept for the reach, which 0.706". Check out www.sparkplugs.com. Very good site.
Old May 15, 2006 | 01:20 PM
Aardwolf's Avatar
Aardwolf
Looks like my car needs the gasket, non tappered style. Ok!
Old May 15, 2006 | 03:45 PM
ED HEISER's Avatar
ED HEISER
You are correct. I had trouble finding plugs for my 88, nobody had them. They kept trying to sell me the short ones for the cast iron heads. I had the Chevy dealer order me a set of Delco's. I never go there for parts, it was weird.
Old May 23, 2006 | 12:03 PM
warrior2291's Avatar
warrior2291
Default Corvette88driver
I used the Bosch Platumin 4 plugs, and they are just great for my 88corvette with aluminumn heads runs smooth and fine,
To '88 tappered plug or not?
