Which Knock module is this?
Old May 22, 2006 | 11:55 PM
Casethecorvetteman's Avatar
Casethecorvetteman
Default Which Knock module is this?
I have the knock module from my 94 sitting here and the part number on it is #16177690, and under that is #1042349. Is this the LT1 knock module or the LT4? Thanks in advance
Old May 23, 2006 | 12:01 AM
bogus's Avatar
bogus
I can't find those numbers... I checked www.gmpartsdirect.com.
my desktop is down right now (bad harddisk) and I can't get to my parts fiche right now... sorry.
Old May 23, 2006 | 12:35 AM
Casethecorvetteman
No worries mate, when i checked that site it told me its a module,EL. I have no idea what that makes it in the grand sceme of things!!
Old May 23, 2006 | 01:46 AM
bogus's Avatar
bogus
I should have my desktop op tomorrow, I can check the fiche then.
Old May 23, 2006 | 09:36 AM
aboatguy's Avatar
aboatguy
My money is on LT1 LINK
LT4 PN= 16214681
Follow this link and enter the PN
Old May 23, 2006 | 10:06 AM
Casethecorvetteman
Thanks Mike Should i go ahead and upgrade to the LT4 knock module? Can anyone see a good reason not to?
Old May 23, 2006 | 11:10 AM
pcolt94's Avatar
pcolt94
I could not cross the numbers but I could find out the the LT1 part # is 10456126 and for the LT4 it is 16214681.
The part #16177690 did not really look right, it crossed to another module it seems. I will look further.
Hope this helps in some way.
Old May 23, 2006 | 11:33 AM
FELNGR8's Avatar
FELNGR8
What you have is exactly what I pulled out of my 94 when I installed the 16214681 (LT4) knock module in my car. I'm looking at my old part that I kept.
Look on the underside of your PCM to check the part number of what's in your car.
Old May 23, 2006 | 11:38 AM
Casethecorvetteman
Pull yours out pcilt94 and have a look at the number on it, its easy to get to, just flip the computer over and on the base there are 2 screws hold the cover over the module which just presses in. See what number yours has on it
Is it a simple clip in and drive away or do i need to do anything else?
Old May 23, 2006 | 12:21 PM
FELNGR8's Avatar
FELNGR8
It is a simple clip in. You might want to pull the battery terminal before doing it, other wise it's the simplest change you can make to the car.
To Which Knock module is this?
