I have a 1985 that I've setup for AutoX. I'm looking for a new clutch, mine has become sort of binary on or off not much in between. I'm running a Richmond 6 Spd trans. Engine has 1.6 rockers, 52 mm throttle body, ported plenum, factory runners.
I'm considering a Centerforce Dual Friction and a Fidanza Aluminum flywheel.
I'm not familiar with the Centerforce II, but since nobody else has responded yet, I'll tell you what I my personal experience has been. I'm not real happy with Centerforce right now, I have a dual friction in my Chevy II, and it appears to have suffered a pressure plate failure. That may or may not be Centerforces fault (from a strength point of view), but prion to this I was already unhappy with the high pedal pressure which has resulted in repeated broken or bent clutch cross shafts, and the clutch smoked on a semi rough pavement attempted burnout with close to 400 Hp on tap and a tiny 235/ 60R15 Radial T/A rear tire (although I gotta admit, many people have commented on how well the car hooks with just old school slapper bars and the tiny rear tires). But over all, I just haven't been real happy with them, and will probably go back with a Hay's Street & Strip Clutch.
Thanks for the reply, I meant Dual Friction ... I've been browsing their stuff and got my fingers crossed on that one.
Yeah ... I've heard mixed reviews on the Centerforce Dual Friction clutches in general.
