Yukon ring and pinions
Old May 18, 2006 | 10:34 AM
RAGOVET's Avatar
RAGOVET
St. Jude Donor '05
Default Yukon ring and pinions
Has anyone had experience with YUKON brand gears.? I am looking to get a set of the 3.54 for my 3.07 carrier.
Old May 18, 2006 | 10:50 AM
RRT vette's Avatar
RRT vette
Did a search for you and found this..
http://forums.corvetteforum.com/show...ighlight=yukon
Maybe a little help.
Old May 18, 2006 | 11:17 AM
RAGOVET's Avatar
RAGOVET
St. Jude Donor '05
Yes thanks. that helps. guess I need to do a search for this stuff first.
Old May 18, 2006 | 02:46 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Yeah, read the 4x4forum links I posted there. Yukon makes more boxes than gears.
Have the parts guy open the box and physically check the gears before shipping, that's the only sure way to get what you want.
I would avoid ordering from Randys Ring/Pinion too. My first hand experience, is their sales&shipping department is full of idiots.
Old May 18, 2006 | 05:39 PM
RAGOVET's Avatar
RAGOVET
St. Jude Donor '05
I decided to use a 2.73 carrier and go with richmond D36 3.54 THICK ring and pinion and replace my existing 3.07 carrier/gears. Richmond is rated better. thanks.
Old May 18, 2006 | 05:53 PM
RRT vette's Avatar
RRT vette
I think thats a good choice. Is it a DD?
Old May 18, 2006 | 07:33 PM
Fuzzy Dice's Avatar
Fuzzy Dice
Cruise-In IV Veteran
FWIW, I ordered 3:73 Yukon's, a posi unit and a master install kit from Randy's...I had them shipped directly to my installer...everything arrived as ordered and on time...the install went smooth as silk and they've been in for about 2 years now...over 150 pases at the drag strip and no whine on the highway...
Old May 19, 2006 | 07:47 AM
RAGOVET's Avatar
RAGOVET
St. Jude Donor '05
Use it as much as I can in good summer weather, back and forth to work, and on weekends for cruises. about 5000 miles per year.
Old May 19, 2006 | 11:58 AM
red L98's Avatar
red L98
my car has yukon gears and they work great , my 60ft are in the low 1.4s
To Yukon ring and pinions
