? about TV cable
Old Aug 24, 2001 | 06:12 PM
ROADAPPLE's Avatar
ROADAPPLE
Default ? about TV cable
I belive the adjustment ratchet on my TV cable is broken. After setting the correct position the next time the throttle linkage is moved to WOT the ratchet returnes to a too loose condition. Am I doing something wrong? Can this adjustment block be replaced or must I replace the whole TV cable? :confused:
Old Aug 24, 2001 | 10:21 PM
Muffin's Avatar
Muffin
Default Re: ? about TV cable (C44ever)
I am going out on a limb and say the block end can not be changed. Are you sure that the locking tab is working as it should. A good cleaning might cure your problem.
