Swaybar bolt problem
Short version, somehow I knocked the bolt back up all the way into the frame. I can't see it.
I need to know how to get access into the frame so I can retrieve the bolt and stick it back down the hole so I can attach the swaybar. This is the passenger side bracket.
There must be a way because DRM had to get in there in the first place to drop the bolts down.
Somehow I manage to make every 1/2 job on this car turn into a major project. This will be the 3rd time the forum has had to bail me out. Thanks for the support and help.
A: be very gifted with really tiny hands and a magic wand
B: cut an access hole to do so
i realize the frames are somewhat different, but on my 84 when i removed my stocker to make way for the BBC they went through the bracket and up into the frame. i had no issues removing them. my front end is also pretty solid so i don't see short of someone hacking a hole in the frame how they could've dropped the bolts in from the top. Unless the differene between early and late C4's really is more than im aware.
