85 ECM removal?
Old May 20, 2006 | 01:00 AM
LangstC4's Avatar
LangstC4
Default 85 ECM removal?
This is probably a stupid question...but after tearing half my dash apart, that is about where I am at. I am in the process of sending my memcal in to be custom tuned, and my Corvette Haynes manual says "remove 3 screws below the dash and take out the ECM". Well...I have removed every screw and plastic piece, and panel I can get to in the front passenger (and driver) side of the car and dont see it. There is a big sponge rubber bumper... a lower carpeted piece with no visible screws...and the top of the dash itself left. Anyone else done this? is it really this hard to do?
There is a huge FAQ section on chips and proms in the forum ...but nothing about just getting it out of the car....flaming about not owning a shop manual is OK hopefully I can't feel any worse
Old May 20, 2006 | 01:36 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
The top dash comes out pretty easy. Remove the dash plastic, (gauge bezel is the trickiest), then undo screws going up into the dash pad (none on passenger side), then two at the defrost vent, and pull it straight back to remove. You'll see the ECM then. It's tight to access from below.
Old May 20, 2006 | 06:59 AM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
I'm a pretty small guy, so it's not too bad for me. You need to take off the bottom part of the passenger side. the part with the light that shines down on the floor. When you get that off, you can look up and see it. Lots of cables in the way. Just pull them down carefully and you'll see it. If I remember right, I used a long socket extension to get the screws loose.
Old May 20, 2006 | 07:44 AM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
I'm a big guy and it is not a bad deal to get out, as was mentioned by Joslinm, take the plastic panel out that has the light in it, pull the wire bundle down and you will see a creme colored box shaped thing with a 10mm screw in each side. Remove the two screws and the ECM will come straight down and out. You may have to work it down around the wiring bundle, no big deal at all. Make sure the battery is disconnected and before you take the small panel off the side of the ECM to remove the PROM touch something on the car to get rid of any static electricity you may have aquired.
Old May 20, 2006 | 08:33 AM
LangstC4's Avatar
LangstC4
Thanks everyone...glad to know I was tearing into the right part of the car at least....I just lost my way for a bit and could not see it with all the wires. I will try it again today...
update ....Finally Got the ECM out and took the small door off....no memcal? There was supposed to be a blue piece held in by some clips...nothing was there. I will keep looking ...almost done (I hope)
Old May 20, 2006 | 10:24 AM
85vet's Avatar
85vet
Cruise-In V Veteran
If your car was running, the chip is there. The plastic covering the chip - may be 1 1/2 to 2 inches long could be blue, white or black - any color. If I recall there are two chips, a small one and a larger one. The larger is the chip that is tuned.
Old May 20, 2006 | 10:36 AM
LangstC4's Avatar
LangstC4
Default ecm chips
I see what looks like 2 chips ...a 2" long black plastic covered object and the smaller one (looks like whatyou described)...does it just pull out? I dont see anthing holding it in. Look soldered.
To 85 ECM removal?
