Broken bolt
Old May 20, 2006 | 09:51 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Default Broken bolt
Today the bolt that holds the leaf up broke, right where the cotter pin goes. Where can I get another one quickly? I have it rigged right now with another nut. Only problem is the it raised the drivers side up about 2in. higher than the passenger side.
Old May 20, 2006 | 09:53 PM
Pete K's Avatar
Pete K
I recall others saying that Lowes carries grade 8 bolts in the correct length.
Old May 20, 2006 | 10:24 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Bless you my son!!!
How where can I get the bushings, without getting a complete set. I lost the bottom bushing, it rolled into the sewer when it broke. Does this happen to alot of vettes?
I think I will get 2 and replace the other side while I am at it.
Old May 20, 2006 | 10:28 PM
Pete K's Avatar
Pete K
Moog may make replacement bushings in rubber. Not too sure though. They are available in poly from energy suspension, if you have no luck finding rubber. Someone on the forum must have a used rubber bushing for you.
Old May 20, 2006 | 11:17 PM
the blur's Avatar
the blur
I have the poly bushings I was NOT impressed with. But the shipping would cost you more than ordering them from Eklers.
How did that break ??? were you driving at the time?
You should carefully inspect your spring for damage.
Old May 21, 2006 | 02:44 AM
Slalom4me's Avatar
Slalom4me
Originally Posted by Randy93
How [and] where can I get the bushings, without getting a complete set.
Why not visit a GM dealer near you?
If I understand you correctly, you need item #42 in the illustration
shown in this post. The appropriate part number is shown and
these are available individually.
Old May 21, 2006 | 03:11 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Whatever else you do, you're better off to replace the bolt with other than an OEM one and use a lock nut. Every story I've heard of these bolts failing was at the cotter pin hole. Obviously, this would be the weakest point. The stock bolt is 14mm but I replaced mine with 16mm diameter. USS equivalents to these sizes would be approximately 9/16" and 5/8" bolts respectively.
Old May 21, 2006 | 09:53 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I don't see how breaking the bolt at the pin hole can cause it to fall apart as the nut is above the pin hole. You wouldn't have be crazy enough to lower the rear using the stock bolts (causing the nut to be below the pin hole), would you
To Broken bolt
